Where is the AC Orifice tube located ??? - JeepForum.com
post #1 of 11 Old 07-30-2011, 11:31 AM Thread Starter
Katmandu
The AC in my 05 Liberty is not cooling well. Not blowing hot air, but not cold either. I checked the freon pressure (2 different gauges), reading about 35psi.
I've talked to a couple techs that suggest the Orifice tube may be blocked and needing replaced. They also suggested replacing the Accumulator/Dryer as well.
Q: Where is the Orifice tube located ??
Any AC repair pics or How-to articles on-line for our Libertys ?
Katmandu is offline
post #2 of 11 Old 07-30-2011, 06:01 PM
streetglideok
2005 KJ Liberty
The only thing in the system that will plug up an orifice tube is material ejected from a compressor, from a mechanical failure inside it. Otherwise, its a closed system, and nothing is going to just plug it up like an airfilter. Was the low side 35psi, or the high side? Does the clutch engage when you start the engine and turn on the a/c? If you only have 35psi on the high side, I bet the a/c never turns on. Low on freon. If the lowside is running 35psi, with the system operating, compressor clutch spinning, then thats within the normal range. Some cars go as high as 40-45psi on the lowside while operating. Replacing the accumulator is suggested whenever you open up the system to service parts. It has an element in there to remove moisture from the freon. Once you get done replacing parts, you have to put the system under a vacuum, then charge it with the specified charge. Whatever you do, save yourself a headache, and dont buy the freon with the sealer in it. Causes more problems then it solves.
streetglideok is offline
post #3 of 11 Old 07-30-2011, 06:19 PM
tjkj2002
2002 KJ Liberty
The orifice tube is in the high pressure line coming off the AC compressor,must replace the whole line as the orifice tube is not replaceable for a KJ.
tjkj2002 is offline
post #4 of 11 Old 07-30-2011, 10:41 PM Thread Starter
Katmandu
Low side, compressor runs w/AC on. Running 35psi and warm air out the vents.
Katmandu is offline
post #5 of 11 Old 07-30-2011, 10:48 PM
streetglideok
2005 KJ Liberty
Then its not a restriction in the orifice line. How cold is the low side line? If you can feel where the lines go into the firewall, either one of them cold? If not, take it to a shop and have an evacuation and recharge done, its likely down a bit on freon, and has some air that has migrated into the system. Doesnt take much to lose performance on the newer vehicles.
post #6 of 11 Old 07-30-2011, 11:22 PM Thread Starter
Katmandu
It's cool, but definitely not cold.
I added 1 can last year. Bit cooler but still not cold. PSI went to 55. Too high and still not cold.
Katmandu is offline
post #7 of 11 Old 07-30-2011, 11:41 PM
Reptile
1991 XJ Cherokee
Is the eFan engaging?
Reptile is offline
post #8 of 11 Old 07-30-2011, 11:45 PM
streetglideok
2005 KJ Liberty
Nope it wont. Old R12 systems, you could get by pumping a can of freon in, as it was pretty forgiving. R134A, forget it. These newer systems are intolerant to inexact charges, both over and under. Only way you are going to get it cold is to have the system sucked down, as in remove the freon into a recycler/reclaimer, evacuation(deep vacuum), then a recharge. If you dont, the air thats floating in your system right now is only doing damage, and the low charge will impede the flow of pag oil, the lube that keeps the compressor running. Hundred bucks or less will get it done right. Have them put dye in it, if there is a leak, can find it later.
post #9 of 11 Old 08-12-2011, 04:33 PM Thread Starter
Katmandu
Yes it is.
I ended up putting another can of R-134a in it. It's much cooler, but still not cold (like I think it should be).
Katmandu is offline
post #10 of 11 Old 08-12-2011, 07:05 PM
streetglideok
2005 KJ Liberty
It probably wont until you do a full evacuation and recharge to the proper level. I see people every week come in, putting the R134 in their car, and amazed it doesnt blow cold. I hook up a machine to ID what is in the system, and find it 25% or more air. Then people get the stuff with the sealer in it. That stuff should be banned, as it does a fine job at plugging machines, and ruining a/c systems. If you really want your a/c cold, and dont wish to fry a compressor, take it to a competent shop so they can do a full vacuum on it, and charge the system.
post #11 of 11 Old 08-12-2011, 09:54 PM Thread Starter
Katmandu
10-4. That'll be next year.
Katmandu is offline
Which Tube can I use splice for Air Intake? thecomposer KJ Liberty Forum 1 04-07-2009 02:20 AM
Gas tank filler tube dougiebuck KJ Liberty Forum 10 12-14-2005 07:34 PM
2 questions about the CRD, where is the fuel filter located? how to find build date? Mike K. KJ Liberty Forum 5 09-17-2005 04:42 PM
Who has an aftermarket intake tube? Liberty LTD KJ Liberty Forum 1 12-27-2003 09:06 AM
pictures of Rusty's air tube installed? DJMJ KJ Liberty Forum 0 06-13-2003 12:47 AM
