When to change spark plugs on '07 jeep liberty - JeepForum.com
post #1 of 30 Old 09-08-2011, 12:51 PM Thread Starter
huntinggal66
2010 JK Wrangler
When do people recommend changing the spark plugs in a liberty? I know the manual says 30,000 but I wanted to see when other liberty owners have changed theirs. Thanks!
huntinggal66 is offline
post #2 of 30 Old 09-08-2011, 12:59 PM
JeepinJarhead03
I do mine at or before 15k, 30k's acceptable, 10k's obsessive.
JeepinJarhead03 is offline
post #3 of 30 Old 09-08-2011, 02:24 PM
Boomerang
2006 KJ Liberty
If I had to change every 15k I would think something was seriously wrong with the engine, even 15k seems obsessive if your engine is doing fine. I guess if you say seafoam once a year this would make sense.
When you know, you know. You know?
Boomerang is offline
post #4 of 30 Old 09-08-2011, 02:30 PM
tjkj2002
2002 KJ Liberty
Every 25k-30k.
Me personally I change mine once a year regardless of miles driven,heck it's like $15 for plugs and 20min job so why not.
tjkj2002 is offline
post #5 of 30 Old 09-08-2011, 02:33 PM Thread Starter
huntinggal66
2010 JK Wrangler
I am currently at 43,000 without changing them. Not having any issues but was thinking they should be done soon. I have heard a lot of opinions from different people so I wanted to see what other liberty drivers were doing.
post #6 of 30 Old 09-08-2011, 02:36 PM Thread Starter
huntinggal66
2010 JK Wrangler
Originally Posted by tjkj2002 View Post
Every 25k-30k.
Sounds like I need to figure out how to do it myself. They want to charge me about $250 at the garage to do them...
post #7 of 30 Old 09-08-2011, 02:40 PM
tjkj2002
2002 KJ Liberty
Yeah book time is 1.1 hours and your not getting plugs for cheap at any shop so $200-$250 is the norm a shop charges for a 3.7 plug change.
I've done so many that's it's nothing anymore.
tjkj2002 is offline
post #8 of 30 Old 09-08-2011, 05:15 PM
Boomerang
2006 KJ Liberty
Jesus! $250??
And they use the cheapest plugs. 1.1 hours? AND they won't even gap them correctly for you - guaranteed.
Buy your own set for 13-15 bucks and grab a wratchet set. It takes me about 40 mins because I spend a lot of time doodling around, checking wires and pipes as well while I'm in there.
Also, I use Channel Lock pliers or similar for removal of the coolant tub up top. 2 bolts, get them off, push the tub to the side so you can reach the back two plugs extremely easy.
Changing the plugs in this vehicle is one of the easiest maintenance projects I've ever done on a car, there is no reason not to do them yourself and save a ton of cash.
Change your plugs and go blow the other $230 at a strip club
post #9 of 30 Old 09-08-2011, 07:26 PM
streetglideok
2005 KJ Liberty
Not all shops have parts installers. I gap all the plugs I install, I can promise you that. I do know plenty of slackers though that dont do the work right, and I get brought in to clean up their mess. Every 30k is what the manual says, and they typically are pretty worn by that point. Its maint. work, so you want to do it before you start having problems. Its easy to do, so if you can handle it, do it yourself. Back just 20 years ago, alot of vehicles still needed plugs every 15k, so it really isnt beyond reasonable. We have all just grown to believe cars go forever.
streetglideok is offline
post #10 of 30 Old 09-09-2011, 02:01 AM
wendell
1987 YJ Wrangler
Why 30,000 miles? Other manufactures are recomended 100,000 miles. Jeep using cheap plugs or what?
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #11 of 30 Old 09-09-2011, 02:36 AM
JeepinJarhead03
i've pulled plugs out of some of those "100k" mile vehicles at 60K and they looked more like ceramic glow plugs at that point
spark plugs are a prime example of declining return on investment
you put in a new plug, and every time it fires, heats up, cools down, it degrades, they don't magically peter out at 30k, 60k, 100k.. or whatever, they slowly degrade. So slowly that most drivers never notice it until they notice something else
A misfire, poor gas mileage, poor performance - and many of them rack it up to . Oh.. well it's getting some age on it
the bosch on the left has less than 40k on it and it was missing +20% of it's electrodes
Plugs on the right had about 96k on them - I was surprised they even fired
I take that back, they weren't firing, the dealer had been charging them diagnostic fees because the engine kept going into safe mode for the last 30k miles with no resolution to the problem and I almost couldn't get the plugs out of the head - had to freeze the plug to get it out
For the cost of the plugs.. it's inane to run them till they literally quit firing
add on top of that.. can't tell you how many plugs I've seen seized in the head after being in there over 60k
Spend the 20 bucks.. or 50 .. or whatever you want to spend, and change the plugs at or under 30k
post #12 of 30 Old 09-09-2011, 11:20 AM
patter5
This guy gives a good explanation on how to change them http://m.youtube.com/index?desktop_u...?v=DxsEOCqhHx8
He shows where the hidden spark plugs are, I hate how jeep doesn't want you to know about the plug behind the steering wheel
patter5 is offline
post #13 of 30 Old 09-09-2011, 11:58 AM
Clockworkorange
2006 KJ Liberty
Got 62,000 miles on my 2006.
I have cleaned the plugs once at about 45,000 miles and they didn't look bad at the time. I'm leaving them in for as long as they work properly and the fuel mileage does not suffer. When it starts to stumble or the mileage goes down I can spend the 40 minutes and change them.
(Note: I have converted my numbers to miles)
Clockworkorange is offline
post #14 of 30 Old 09-09-2011, 01:22 PM
01CHEEKEE
it really is simple to change plugs on this vehicle, i believe there are a couple youtube vids showing how to do it...rear passenger is the hardest, and as someone said it simply requires pulling the coolant tub which has 2 screws...
01CHEEKEE is offline
post #15 of 30 Old 09-09-2011, 06:02 PM
streetglideok
2005 KJ Liberty
You guys that want to wait until it starts to run bad, do you know how much the computer will compensate to keep it running, before you will see changes? How much do cats cost, and do you know what causes them to melt down? Plugs are sure cheap to change when your supposed to!
Change Spark Plugs on an 02-07 Jeep Liberty KJ jp7794 KJ Liberty Forum 136 11-21-2015 05:45 PM
Help 2003 Jeep Liberty Freeze plugs jbaronski KJ Liberty Forum 0 06-23-2010 05:24 PM
'05 Liberty Spark plug and coil change bieakma KJ Liberty Forum 8 12-07-2009 12:09 PM
Replacement Spark plugs, 2005 KJ Liberty? adidasf50soccer KJ Liberty Forum 3 09-07-2009 02:13 PM
Where are the spark plugs on an 06 KJ, Clockworkorange KJ Liberty Forum 4 04-23-2009 08:00 PM
