Wheel compatibility for an '03 Liberty Limited - JeepForum.com
post #1 of 4 Old 03-01-2008, 10:58 AM Thread Starter
Bluebell
2003 KJ Liberty
I recently got rid of an old Cherokee and got an '03 Liberty Limited. I'm sure this has been discussed but I did a search and came up empty.
What other Jeep wheels will fit an '03 Liberty without having to get things like adapters, spacers, etc.? I'm not concerned about things like wheel width or height because I should be able to figure that out myself. My question centers around the lug pattern.
Based on some preliminary research, it looks like some Grand Cherokee wheels are a direct fit (i.e. no mods needed.) What's throwing me off is I know I've seen both Grand Cherokee and Wrangler wheels on Cherokees yet I'm pretty sure Wrangler wheels are not a direct bolt-on to a Liberty.
I've also seen some info indicating Commander wheels are a direct bolt-on to Liberties. Also, since the Dodge Nitro is so similar to the Liberty, what about Nitro wheels? Or Patriot or Compass wheels?
Pardon all the questions, but I'd really like to know. Thank you.
Bluebell is offline
post #2 of 4 Old 03-01-2008, 01:19 PM
LoneLiberty
2004 KJ Liberty
Lug pattern is 5 on 4.5, 16X7 with 5.5" back spacing.
Slightly Modified O4 Liberty LTD
Pix/Mods:
LoneLiberty is offline
post #3 of 4 Old 03-02-2008, 07:49 PM
rustym38a1
rustym38a1's Avatar
1953 M-38
Remember you have a 5 on 4.5" bolt pattern. You may run into brake gap tolerances between the rim and the brake caliper if you try to install a 15" wheel. The only Wrangler wheel that would fit would be from the Rubicon(16").
There was also a couple of Cherokee wheels, the Icon from 2000 and the Ultra Star from 2001 that were 16" and would fit.
I put a set of ZJ Grand Cherokee (93-98) 16" wheels called Luxury on my daughters 02 with no problems. The WJ Grand (99-2004)switched to a 5 on 5" bolt pattern along with the new Grands and Commanders.
They won't work.
11 Wrangler Rubicon JK 'Call of Duty Black Ops Edition' 2 Door, 6 spd with Magnaflo exhaust, Banks Air intake, 34" Nitto Terra Grapplers
08 Liberty Limited KK- Sky Slider -Every option available at time (wife's car)
04 Sahara TJ- OME suspension, Borla Exhaust, Rusty's Skids, K&N, LED's, Pro Comp 31's
97 Wrangler SE TJ- This is our Trail Jeep. Yukon 4.88's, Powertrax Locker, 32" BFG KM2 tires, XRC/8 winch
53 Willys M38a1- Restored w/50cal Browning M2HB & 53 M100 1/4 ton Trailer fully loaded with gear!
13 Grand Cherokee Laredo WK2- company car
rustym38a1 is offline
post #4 of 4 Old 03-06-2008, 09:10 PM Thread Starter
Bluebell
2003 KJ Liberty
Wow! Thanks for all that info!
Bluebell is offline
Liberty KJ rear brake pad compatibility? sprintagogo KJ Liberty Forum 1 03-28-2009 08:58 PM
Wheel and Tire, 2002 liberty limited twinjeep97 KJ Liberty Forum 2 12-28-2008 06:30 PM
Looking to buy a 2006 Liberty CRD Limited LAjeep KJ Liberty Forum 19 11-08-2008 06:53 PM
02 Liberty Limited Questions SouthernStyle KJ Liberty Forum 13 12-04-2007 11:57 AM
My new 03 Liberty Limited! Liberty LTD KJ Liberty Forum 1 12-02-2003 10:51 PM
