Wheel Bearing Replacement - JeepForum.com
post #1 of 7 Old 09-29-2010, 09:04 AM Thread Starter
JeepLiberty06
I need to replace my wheel bearings on my 06 Jeep Liberty, i have found that detroit axle sells them the cheapest, i wanted to know if it is simple straight forward or if i will require a hub puller? Im pretty sure torque specs should be 175, let me know how difficult this is going to be???
Thanks
Patrick
JeepLiberty06 is offline
post #2 of 7 Old 09-29-2010, 01:11 PM
richd
2008 KK Liberty
Thanks
Patrick
This will show how to remove the axle,and the bearings:
2003 Jeep Liberty Service Manual.pdf (pdf document) free file download at fliiby.com
richd is offline
post #3 of 7 Old 09-29-2010, 09:28 PM
richd
2008 KK Liberty
This is something I just put up in another thread.Hope this helps:
These are easy to do.You need like tj said remove cover,turn the axle untill you see a small bolt holding a retainer.You will see the pinion shaft.That what the retainer is keeping in place.Unbolt the retainer,and carefully pound out the pinion shaft out of the diff.case.With the pinion shaft removed,push in the axles,remove the c-clips,remove axle.Remove seal then bearing.
richd is offline
post #4 of 7 Old 10-11-2010, 06:14 PM Thread Starter
JeepLiberty06
Well mine was simpler than this?? Not sure why, i removed all brake components, took an impact to the axle nut which did not have a retained on it nor does it have a hole for a retainer??? interesting? took the three E-Torx bolts out of the back, size E-14 then i took the back of an axe and beat the wheel bearing out as it was slightly frozen in, got it all out and got the new ones in within matter of 20 minutes and everything back together. However i still have that same noise, whob... whob.... whob.. whob. whob. whob the faster i go?? Could my rear wheel bearings be bad? Maybe ball joints? Seems to only intensify when i make left hand turns, not when making right hand turns? Could tires need balanced possibly? I am lost as usually this problem is solved with wheel bearings? Please let me know any other suggestions, everything is to torq, axle nut 100 ft/lbs E-Torx i think also 100 ft/lbs cant remember now. This is driving me crazy.
post #5 of 7 Old 10-11-2010, 07:03 PM
tjkj2002
2002 KJ Liberty
The CV joints can be to blame,as is the passenger side shaft in the diff,the front driveshaft can be a issue also,and finally yes the rear axle bearings can be at fault also.
tjkj2002 is offline
post #6 of 7 Old 10-11-2010, 10:57 PM
SabaII
Easiest thing to do is to swap tires side to side. Takes a few minutes and just gets rid of them as a possibility. Then as tjkj said any of the rest can be to blame.
And your lucky. I had a wheel bearing go out in my 02 Stratus and I have to press the cv out of the hub it was that seized. BTW dont ever buy a stratus.
SabaII is offline
post #7 of 7 Old 10-12-2010, 06:38 AM
bradbb2005
2008 WK
Questions answered -
http://bradbb2005.dyndns.org:13000/F...ub-Bearing.pdf
Current:
2008 WK Limited 5.7L HEMI
Mods: | JK Moabs | 245/70-17 General Grabber AT2 | 1.25" Wheel Spacers
2008 KK 3.7L V6
Mods: | 225/65-16 General Grabber AT2 |
bradbb2005 is offline
04 liberty ac bearing replacement gorilla13 KJ Liberty Forum 16 05-29-2015 09:22 AM
2002 Liberty - wheel bearing jlupien502 KJ Liberty Forum 13 08-23-2010 07:17 PM
Wheel Bearing play Micah1234 KJ Liberty Forum 1 07-13-2010 09:09 PM
Wheel Flare Replacement janschutz KJ Liberty Forum 2 03-19-2008 02:19 PM
Thrust/Release Bearing replacement daxiet KJ Liberty Forum 0 02-14-2008 12:50 AM
