What year of Jeep Liberty Limited do you have? - JeepForum.com
post #1 of 15 Old 11-07-2013, 06:55 PM Thread Starter
Krissypoo29
Also can you state the km's and any major repairs? Thanks
Krissypoo29 is offline
post #2 of 15 Old 11-07-2013, 06:59 PM
tjkj2002
2002 KJ Liberty
'02 Limited here,93,000 miles(not KM's),no major repairs ever.
tjkj2002 is offline
post #3 of 15 Old 11-07-2013, 10:05 PM
oilbuner
2006 KJ Liberty
2006 Limited CRD, Well maintained. 100,000 Mi+-
When the pavement ends, you better have some ground clearance!
oilbuner is offline
post #4 of 15 Old 11-08-2013, 06:14 AM
banzyskj
03 liberty freedom edition just cracked 110,000 only major repairs were balls joints uper and lowers
banzyskj is offline
post #5 of 15 Old 11-08-2013, 06:21 AM
tommudd
2004 KJ Liberty
Why just Limiteds?
Nothing different except the trim/ seats , drivetrain etc basically the same
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
post #6 of 15 Old 11-08-2013, 06:59 AM
olliehopnoodle
1982 FSJ Cherokee
2002 Limited 160000 miles. Transmission/engine rebuilt due to running it out of oil/radiator/ball joint recall/window regulators/stereo was replaced (speakers had gone out)/water pump (many many miles ago)/fuel rail (from me having to do move it so many times messing with the engine)/a couple of batteries
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #7 of 15 Old 11-08-2013, 07:56 AM
TomSawyer
2002 KJ Liberty
'02 ltd just bought 6mo ago overheated/low coolant cracked the radiator replaced. 124k carfax was cleaner than a cats a**.
TomSawyer is offline
post #8 of 15 Old 11-08-2013, 09:32 AM
olliehopnoodle
1982 FSJ Cherokee
You might consider replacing the seats on the intake valves. It's a PITA job to do yourself (have a machine shop do the actual seats) or expensive if you take is somewhere BUT a dropped seat can take out the entire motor.
post #9 of 15 Old 11-08-2013, 06:00 PM
NCSahara
2006 KJ Liberty
06 Limited 45k miles. Just did shocks and struts and first tune-up and did a diff service.
NCSahara is offline
post #10 of 15 Old 11-18-2013, 08:54 AM
06LibertyCRD
2006 KJ Liberty
06 CRD Limited - Timing Belt & Water pump at 118,000 miles, now at 122,000 (this was preventative maintenance, not broken, just making sure it doesn't end up broken :-) ).
06LibertyCRD is offline
post #11 of 15 Old 11-18-2013, 04:53 PM
jbarthol
2005 KJ Liberty
05 Limited, 114,000 miles. Water pump. Wire splice under the divers seat due to a corroded wire disabling the power windows. Preventive stuff includes rear wheel bearings, one U-joint on the rear drive shaft. Other one I am waiting to do because I want enough money to get one of those "c clamp press" before attempting, as the BFH and crappy socket method gave me one nasty headache.
jbarthol is offline
post #12 of 15 Old 11-18-2013, 07:04 PM
rmadona
2007 KJ Liberty
07 baught it for my daughter about a year and half ago. 70,000 miles 6 months ago had the driver window repaired at the dealer.
rmadona is offline
post #13 of 15 Old 11-19-2013, 07:30 AM
DaveJKJ
2005 KJ Liberty
05 ltd, 74K, just routine maintenance done by me except for the ball joint recall and rear control arm recall and it was at the dealer for those. Been wheeled mostly easy but hard a few times.
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
post #14 of 15 Old 11-29-2013, 10:25 PM
FATCAT123
2006 KJ Liberty
06 Liberty CRD: 90,000 miles. Had to replace 2x window motors (1 front and 1 back). Started smoking and power loss. it turned out to be a crack in the turbo hose. The only expensive replacement was the alternator. It is still running strong.
FATCAT123 is offline
post #15 of 15 Old 12-01-2013, 01:20 PM
Jeepguy4276
2002 KJ Liberty
'02 sport 4x4 auto 178000 miles-carfax shows well maintained at dealership until 2010 then new owner did some at shops but most done himself with records. I've done all my own stuff other than oil change and rotate because I have an elite rewards Kmart/sears card that we get a $4.95 oil change and tire rotate twice a years. The radiator was replaced and the water pump thermostats hoses were done at the same time. A power steering hose was replaced. An installer that put autostart in did a terrible job soldering to an ignition wire and frayed it. I rewired that and did plugs, all fluids, maintainence items. Replaced the radio that Po messed up. Replaced the regulator piece that breaks on them. Regular maintainence things. I did have to replace the speed sensor and wiring to it (common problem). I'm replacing all 4 brakes (general wear item) And an o2 sensor this week. Done a couple light bulbs. Replaced the seatbelts because po's husky liked to chew. I'll need to fix the blend door. Motor had great compression, diffs look perfect, tranny and tcase seem great. Truck runs and drives great.
***i just noticed you specified limited. Sorry, I'm a *******.
Jeepguy4276 is offline
