What is this?(pic) - JeepForum.com
post #1 of 18 Old 06-22-2014, 09:26 AM Thread Starter
02jeepliberty
What is this?(pic)
I have the OTIS on my 02 sport, I was going through all the different things and I can't figure out what this is for and how I get rid of the "-.-" any help??? Thanks
02jeepliberty is offline
post #2 of 18 Old 06-22-2014, 07:10 PM
lfhoward
2008 KK Liberty
Looks like the trip odometer. It should show numbers once you start driving. Not 100% sure though, as I have an '08.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #3 of 18 Old 06-23-2014, 06:59 AM Thread Starter
02jeepliberty
it's always been like this, I don't know how to change it and get rid of the dashes
post #4 of 18 Old 06-23-2014, 09:29 AM
Tombo_ontario
2002 KJ Liberty
Definitely the trip odometer...its obviously acting up as it should be continually counting kms/miles as you drive. I'd say check your speed sensor in the transmission as I think that's the one that the odometer uses though I could be wrong. If your speedo is working I'd doubt anything is wrong with the rear speed sensor in the rear diff.
Tombo_ontario is offline
post #5 of 18 Old 06-23-2014, 10:38 AM Thread Starter
02jeepliberty
I did add this overhead console, do you think that might be why it's not working correctly? Everything else works perfectly fine, except this
post #6 of 18 Old 06-23-2014, 12:06 PM
Tombo_ontario
2002 KJ Liberty
I've read that if you got your OTIS from a vehicle pre 2000, the trip odometer will not work if you install it in a 2001 or later vehicle because the BCMs are incompatible...that could be the problem.
post #7 of 18 Old 06-23-2014, 01:44 PM Thread Starter
02jeepliberty
I read that too, this one came out of a 2002 concord. And I have an 02 liberty. So it should work, right?
post #8 of 18 Old 06-23-2014, 02:29 PM
remmons
Maybe it could be a compatibility issue since it did come from a different vehicle. The Concords VSS (vehicle speed sensor) may have a different pulse signal than the Liberty. There is another thread with similar issues. http://www.jeepforum.com/forum/f28/o...-help-2490593/
Turns out it was a compatibility issue from a different year KJ.
Robert.
remmons is offline
post #9 of 18 Old 06-23-2014, 04:58 PM Thread Starter
02jeepliberty
Originally Posted by remmons
Maybe it could be a compatibility issue since it did come from a different vehicle. The Concords VSS (vehicle speed sensor) may have a different pulse signal than the Liberty. There is another thread with similar issues. http://www.jeepforum.com/forum/f28/o...-help-2490593/ Turns out it was a compatibility issue from a different year KJ.
haha turns out I was the one that posted the info and helped him out, but I already knew that info, I didn't know that this would be an issue as far as compatibility for that feature...
post #10 of 18 Old 06-24-2014, 06:59 AM
remmons
Sorry, didn't mean to step on anyone's toes. I have read elsewhere that this was the issue, and I found your thread to follow the same path.
Robert.
remmons is offline
post #11 of 18 Old 06-24-2014, 08:20 AM Thread Starter
02jeepliberty
No problem at all, I just thought the thread looked a little familiar I've ordered another one but an evic from an 02 grand cherokee, maybe this'll work. Thank for the help!
post #12 of 18 Old 06-24-2014, 03:40 PM
remmons
Let me know how it works. I have my eye on one at my local salvage yard, but I haven't taken the plunge yet as that I haven't heard that many success stories on these yet.
Robert.
remmons is offline
post #13 of 18 Old 06-24-2014, 03:48 PM Thread Starter
02jeepliberty
the one I have works perfectly fine and is accurate, the only thing that doesn't work is this thing in the picture. It was easy to install and I actually bought a harness for it on eBay. If I had to install it again, I would.
post #14 of 18 Old 06-25-2014, 09:04 AM
remmons
That's good to know. Thanks.
Robert.
remmons is offline
post #15 of 18 Old 07-02-2014, 05:09 PM Thread Starter
02jeepliberty
Just an update, installed an EVIC from an 02 GC and everything works properly, even all the menu features. The only thing that doesn't work properly are the graphics displayed when doors are open. When drivers door is opened, it works. But when any other single door is opened it says "all doors open" with the vehicle displayed with all 3 doors open except drivers. Other than that, it works perfectly. I did notice it was a tight squeeze though compared to the OTIS. It also doesn't power on/work when the key is turned to the left, as my other one did. Is this normal? Also, the OTIS made the vehicle chime when any buttons were pushed on it, the EVIC does not. Is this normal? Finally, does anyone know an approximate cost on how much it would be to get the BCM reprogrammed to the EVIC? Thank you
