Weird candle wax smell?? - JeepForum.com
post #1 of 3 Old 10-21-2010, 11:23 AM Thread Starter
jonger
2003 KJ Liberty
Past couple of weeks been having a bit of weirdness with my 03 lib. After driving about 5 miles i get a strong smell like when you blow out a candle, slight smoke coming from who knows where since I am usually not anywhere to be able to pull over to identify the location its coming from. minutes later it is gone and does not happen again during my commute. now its happening every day.
All the fluids are good... suggestions?
jonger is offline
post #2 of 3 Old 04-21-2014, 10:07 AM
andresqr
Hi Jonger, did you ever figure out what was producing the weird candle wax smell in your Jeep? I'm having the same issue as you were, exactly as you described it and it is driving me nuts
Thanks man
Andres
andresqr is offline
post #3 of 3 Old 04-23-2014, 07:23 AM
TwoBobsKJ
2003 KJ Liberty
Originally Posted by andresqr
Hi Jonger, did you ever figure out what was producing the weird candle wax smell in your Jeep? I'm having the same issue as you were, exactly as you described it and it is driving me nuts Thanks man Andres
That's an old thread from 2010 but to answer your question...
It's probably the valve cover gasket leaking oil onto the catalytic converter. If you get the smell when coming to a stop - and you occasionally see a puff of white smoke - then it's the valve cover gasket(s) for sure. Only one may be causing a noticeable problem but the other one isn't far behind.
Not a technically hard fix but the driver/left side is much easier since you don't have to move the heater core hoses out of the way like you do on the right/passenger side.
There are How-To's over on JeepKJ.com to show you the steps. Hope this helps!
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
Gas Smell hig KJ Liberty Forum 16 10-17-2014 02:42 PM
Skunk Smell Haggertus KJ Liberty Forum 2 06-05-2010 02:17 PM
burning smell be_at_eaze KJ Liberty Forum 3 03-08-2010 07:40 AM
Diesel Smell rmnoonan KJ Liberty Forum 11 11-28-2005 08:10 AM
Weird smell from cab at 65+mph hyedipin KJ Liberty Forum 26 04-27-2005 09:19 PM
