Washer Fluid & Rear Wiper not working - JeepForum.com
post #1 of 8 Old 01-01-2009, 08:12 AM Thread Starter
Glenwood1991
2007 KJ Liberty
2007 Jeep Liberty - Rear wiper and washer does not work. The fuse for the rear wiper is good. Is there something else I should be checking?
Glenwood1991 is offline
post #2 of 8 Old 01-01-2009, 08:31 AM
jeeprscreeprs04
2004 KJ Liberty
My 04 just quit working one day out of the blue too. I have no idea but am curious as to what it could be.
jeeprscreeprs04 is offline
post #3 of 8 Old 01-01-2009, 05:36 PM
STSMWR
2003 KJ Liberty
My rear wiper doesn't work either (03 Liberty) and I paid $85 for an estimate of $385 to replace the rear wiper motor. I can live without it.
STSMWR is offline
post #4 of 8 Old 05-14-2011, 03:01 PM
craigarbo
Any updates?
My jeep has the exact same problem. Has anyone found a solution for this?
craigarbo is offline
post #5 of 8 Old 05-15-2011, 02:48 AM
Billwill
2002 KJ Liberty
Does the washer motor make a noise when you operate the switch to clean the rear window?
The washer container has the washer motor inbedded in it, the motor rotates in one direction to direct water to the front screen if you are trying to clean the front and the motor runs in the opposite direction to clean the back...a system of valves directs the water to the correct area.
If the washer motor is dead and the rear wiper does not attempt to move when attempting to wash the rear window...I would suspect that the wiper stalk switch is faulty. I will look at my 2002 circuit diagram...should be close enough to the 2007 model....and see if I can think of anything else!
Billwill is offline
post #6 of 8 Old 05-26-2011, 07:14 AM
craigarbo
The rear wiper makes no noise at all. The fronts work fine except for when I pull the wiper arm toward myself, no fluid sprays and the wipers don't turn on either. This has got me really confused. I shot the wires back to the rear wiper and it seems to be getting power - 12V.
post #7 of 8 Old 05-26-2011, 11:35 AM
Billwill
2002 KJ Liberty
What year model is your KJ?
Does the spray work on either front or back or not at all?
Edit to add: For multiple wiper/washer problems I would suspect first the Multifunction Switch on top of the steering column and then a problem in the BCM which drives most of the wiper functions! Obvioulsly check all fuses and swap over/replace the wiper relays.
Billwill is offline
post #8 of 8 Old 06-01-2011, 10:46 AM
craigarbo
Neither the front or the rear work. The Jeep is a 2005 Liberty.
windshield washer not working peg KJ Liberty Forum 22 02-22-2016 09:20 AM
Self filling washer fluid??????? Mr_Harry KJ Liberty Forum 10 08-08-2009 07:08 PM
Windshield washer fluid problem terrysliberty KJ Liberty Forum 3 11-14-2006 01:22 PM
Windshield Washer Fluid Squirter RebelsPlaya069 KJ Liberty Forum 0 02-18-2005 03:51 PM
Rear window washer not working moopa KJ Liberty Forum 6 03-07-2004 11:27 AM
