Want to add button to stick shifter (manual tranny) to shut off lift bar - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Want to add button to stick shifter (manual tranny) to shut off lift bar
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiPoison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 01-20-2005, 02:22 PM   #1
swyszomirski
I want to add a momemtary button to my stick so I can turn off the light bar quick when someone is coming at me, but the switch has a relay in it. Anyone done this before?
swyszomirski is offline   Reply With Quote
Unread 01-20-2005, 03:42 PM   #2
belezeeubub
2007 MK Patriot
Sure get a 30 or 40Amp NC relay and wire it up to a switch on the shift knob I suggest "racerboy" they make a great deal of RF and IR Gear Shift knobs with 2 to 6 buttons each (normally used for NoS or Go-go lights it would do the job)
Find the Power Wire comming from the exsisting switch to the Light bar and Splice in the NC relay, (an NC relay is a relay that is normally closed and when power is applied it opens)
belezeeubub is offline   Reply With Quote
Unread 01-20-2005, 09:28 PM   #3
Mateo94XJ
Yeah, that'd probably be easier than my suggestion.
I just don't naturally think "Rice" to solve problems haha, even though a valve cover breather makes a great air intake for an onboard air pump. . .
'94 XJ Sport 2dr.
'86 MJ
'42 Willys MB
Mateo94XJ is offline   Reply With Quote
