Visible Oil Leak near rear of engine - JeepForum.com
post #1 of 5 Old 01-30-2014, 10:08 AM Thread Starter
libertyflyer
2004 KJ Liberty
Hi everyone. I'm having trouble finding an oil leak.
Been driving this jeep since 20k miles and haven't had any oil issues. Im now at 108k and there is a visible leak.
We recently moved to NH and I've been using the 4WD quite a bit because of the snow. I noticed a burning oil smell and recently saw some smoke coming from the engine near the rear.
Upon further investigation, I saw oil dripping down from the left side of the engine (if you are facing the Jeep). It's dripping from the rear somewhere and it falls directly onto the exhaust right before it meets the Cat Converter. I can't seem to see where exactly its coming from.
Any ideas?
libertyflyer is offline
post #2 of 5 Old 01-30-2014, 11:12 AM
Bnova
2006 KJ Liberty
I just saw a post here recently that the valve covers can leak at the rear end of the cover and drip right down onto the exhaust and not be seen probably without a mirror and flashlight.
Bnova is offline
post #3 of 5 Old 01-31-2014, 06:41 AM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Any ideas?
The valve cover gasket is known to leak at the rear closest to the firewall. Oil seeps out from under the gasket, forms a drop on the cylinder head, and then falls down to the exhaust manifold and/or the catalytic converter. When the oil is burnt it rises up and is sucked into the HVAC cold air intake at the cowl - makes for a glorious smell in the passenger cabin
The gasket replacement isn't that difficult - but on the passenger side it's a bit more challenging due to the heater core lines that must be removed from the firewall and the coolant reservoir must be moved out of the way. Neither of those two tasks is difficult - just a couple more things to do vs the driver's side.
When you install the new gaskets be sure to use the new grommets that come with the gasket set - pop the old grommets out of the valve covers and press in the new grommets.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #4 of 5 Old 01-31-2014, 01:50 PM
USPLiberty
You can check the valve cover for leaks, and there is plastic "something" on the lower passenger side just below the valve cover that can also leak. Having an inspection camera helps a lot, you can't see very far into these tight modern engine compartments.
USPLiberty is offline
post #5 of 5 Old 01-31-2014, 02:28 PM
tommudd
2004 KJ Liberty
98% sure its the valve cover, easy fix
Took me longer to grab tools than to fix it almost
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
