Vibration Damper Shims 2002 3.7 - JeepForum.com
post #1 of 5 Old 04-19-2012, 09:30 PM Thread Starter
gjinc
Ok, I replaced the motor in my parents 2002 Liberty
Everything went good except now the belt squeals.
I put some bar soap on the belt and the squeal went away for
a short amount of time. Looking at the belt alignment, it looks
like the vibration damper needs to come out a small amount.
The belt is riding in a slightly different place on the closest pulley.
I have been doing web searches and have come up with nothing so
Does anyone know if shims are available?
Thanks
gjinc is offline
post #2 of 5 Old 04-19-2012, 10:12 PM
streetglideok
2005 KJ Liberty
Did you install a new belt, or reuse the old one? Were your hands clean, or greasy/oily? If any of that is the case, or the pulleys werent cleaned prior to belt installation, that can be the source of your noise. What pulley are you referring to, when you say the closest pulley?
streetglideok is offline
post #3 of 5 Old 04-19-2012, 10:28 PM Thread Starter
gjinc
new belt, cleaned everything, clean hands
the closest pulley is just a idler pulley
thanks
gjinc is offline
post #4 of 5 Old 04-20-2012, 07:35 AM
streetglideok
2005 KJ Liberty
I would look closely at the pulleys then. CHances are, the rest of the pulleys look to line up, and the idler is the odd man out, and you are seeing the belt run on it where there is paint still, and an area of the pulley where its not is shiny. Did you have to install the idler pulley? Was there a spacer on the back side, etc?
post #5 of 5 Old 04-20-2012, 05:24 PM Thread Starter
gjinc
I had to move the idler pulley from the old motor to the new motor.
I see shinning metal from where the belt used to run.
So it is running on a painted area now
I moved everything that was on the old motor.
The odd man out looks like the vibration damper, looks like it needs to come out a bit.
Thanks
gjinc is offline
Damper Removal without special tool insert? blakeusa KJ Liberty Forum 2 12-10-2013 12:35 AM
How Hot Should A 2002 JK get? BoosLibby KJ Liberty Forum 5 06-15-2010 10:36 PM
2002 Liberty front vibration rpshadow KJ Liberty Forum 3 03-19-2009 08:18 AM
2003 3.7 in a 2002? wtobin1959 KJ Liberty Forum 6 02-24-2009 10:04 PM
2002 liberty gregandmichelle KJ Liberty Forum 3 12-05-2008 03:25 AM
