Very Weird Squeaking from Front End - JeepForum.com
post #1 of 6 Old 09-23-2009, 06:32 AM Thread Starter
SilverGT
2004 KJ Liberty
Well I just got finished replacing my wheel bearing last night and went for a test drive
This is what i did to do the wheel bearing.
equipment needed
36mm socket
3/4 SAE socket
8mm socket
10mm socket [this will be if you stripped the wheel bearing bolts lol]
7/16 sae socket
Ratchet
Breaker Bar
1. Jack up the car up
2. Take off the wheels
3. Try to secure the hub from spining.
-What i did for this was i took the wheels center cap off by unscrew three 8 mm bolt on the back side of the center caps
4. I put the wheels back on with like 2 lug nuts, lower the vehicle enough just to get the wheel on the floor without the whole weigh of the car on it
5. Brake the Axle nut off its a 36MM Axle Nut
6. Take the wheel back off
7. Take the Caliper bracket two 3/4 SAE bolts the rotor pads caliper and bracket will come out all at the same time [lol i was lazy so i took it all out as 1 piece]
8. have a something to rest the brake unit on something
9. unbolt the wheel hub bearing out. three 7/16 SAE bolts [if you strip them go to a 10mm and pound it in with a hammer.
10. take a sledge hammer and out the back side of the hub it will come off pretty easy
So now on to the question.
AFTER doing all this i took it for a test drive. drove it around and cant seem to find out why there is a squeaking sound.
Car has 196k miles, i dont think the car has recently have a brake service as the rear brakes look like corroded and warped.
These are the test i performed
The squeaking is always present in motion but more profound at lower speed less then 30mph. When you apply the breaks hard it the sound goes away. if you apply it medium it gets louder. if no breaks are applied they are lower squeaks.
I personally thinks its the brakes its self and nothing in the wheel or suspension that would do that would it?
I did noticed the brakes did also pulsated during higher speed breaking 60mph+ so it could also be a warp rotor.
at first i thought it was the wheel not being tight but they were in fact tight.
What are your thoughts and opinion on this?
SilverGT is offline
post #2 of 6 Old 09-23-2009, 07:26 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
I have to definitely agree wit the brakes and most likely the warped rotor
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 6 Old 09-23-2009, 08:58 AM
gorilla13
Check your pads for uneven wear also. Then replace the rotors and pads (cheap fix) if you find that their is a wear issue.
gorilla13 is offline
post #4 of 6 Old 09-23-2009, 09:02 AM Thread Starter
SilverGT
2004 KJ Liberty
Front Brake Pads and Rotors have been ordered, Hopefully this will fix the squeaking....i will post updates to see if it is indeed the rotors and pads.
SilverGT is offline
post #5 of 6 Old 09-23-2009, 10:03 AM
04KJlimited
2004 KJ Liberty
check to make sure the dust shield isnt contacting the rotor. they are very easy to ben, most times you dont even realize you have. turn the wheel so you can see it and clearance it a little bit with a screwdriver and usuallyh that fixes it
04KJlimited is offline
post #6 of 6 Old 09-23-2009, 11:25 AM Thread Starter
SilverGT
2004 KJ Liberty
That what a freind of mine said too but to counter that idea:
Why would it stop when you step on the breaks hard but not hard enough to come to a complete stop the squeaking goes away.
SilverGT is offline
Front drive shaft squeaking Clockworkorange KJ Liberty Forum 8 10-05-2009 01:15 PM
Squeaking Front Suspension Elt31987 KJ Liberty Forum 2 07-28-2009 09:03 AM
Squeaking Shocks sqliberty KJ Liberty Forum 1 05-28-2009 05:48 PM
09 KK Squeaking Brakes spolebitski KJ Liberty Forum 3 03-22-2009 07:58 PM
Squeaking when going over bumps Liberator KJ Liberty Forum 2 02-01-2008 04:12 PM
