Turn Signal Fuse - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Turn Signal Fuse
Don't forget the Jeep Forum discount, 10% off!Ruffstuff Axle Simple Swap Kit!The Original 3/8" Ruffstuff Diff Cover!
Unread 10-17-2014, 07:43 PM   #1
becks7575
Turn Signal Fuse
Hello
I have 2006 Jeep Liberty. Everytime the "Turn Signal" and Defroster are used at the same time the "Turn Signal" fuse blow out and I have to replace it. Any thoughts regarding what is going on?
Thanks
James
becks7575 is offline   Reply With Quote Quick reply to this message
Unread 10-18-2014, 03:44 AM   #2
Billwill
2002 KJ Liberty
Originally Posted by becks7575 View Post
Hello
Thanks
James
Which fuse number is that exactly?
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline   Reply With Quote Quick reply to this message
Unread 10-18-2014, 08:18 AM   #3
becks7575
I don't know to be honest. I had it fixed it at a shop. The mechanic was not able to figure out what was causing it.
Unread 10-18-2014, 02:20 PM   #4
kjsteve
2002 KJ Liberty
I quick looked up an 06 KJ manual online and it says that fuse #7 is for the left parking lights/left tail lamp/license plate lamp and fuse #9 is for the right park light/right tail lamp/license plate lamp/cluster. Now this is in the interior fuse block, not under the hood.
The defroster/heated mirrors is fuse #29.
[QUOTE=1998zj;10145090]"HOT water heater" Why do you need to heat hot water.[/QUOTE]
KJ Liberty
kjsteve is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:04 AM   #5
becks7575
Both the defroster the signal lights works separately. Problem occur when you turn both at the same time. Do you think the problem is with the fuse or it could be a wiring issue?
Unread Yesterday, 09:20 AM   #6
mjuenem
2005 KJ Liberty
There are two turn signal fuses according to the previous post (fuse #7 and fuse #9). Exactly which fuse is blowing? Or which turn signal stopped working (R or L)?
Mark
mjuenem is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 01:49 PM   #7
becks7575
I think when the defroster was on and I turned left and is it blew up.
