Transmission and Rear-end Problems
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
My father in law has 2005 Jeep Liberty Limited and at 80,000KM the rear-end needed new bearings and seals. Then at 90,000KM the transmission needed to be completely overhauled. Now he is finding a vibration in the rear at 100K. Has anyone else experienced similar problems with the KJ style? Driving pattern in 90% highway at 100 to 110KM per hour. He owns a small camper, 2000pds that is hauled and a utility trailer. He is the second owner and was told when he bought it that the previous owner had towed a camper weighing 4000pds during the summers. The Jeep was only 2 years old we he bought it but could the towing by the previous owner contribute to the issues he is having now.
2008 Jeep Liberty North Edition |
#2 |
Vibrations in Rear
My guess these vibrations are felt at highway speeds. Is there a rubbing noise or slight growl sound? Brakes can also simulate vibrations.
Does the rear differential have the Trac-Lok? I would recommend that you or a shop, 1-check rear Universal joint and 2- pull the differential cover and have a look in there, replace with synthetic gear oil, see if there is wear on the teeth or clutches. If it is a Trac-Lok differential the clutches are probably worn out (they don't last that long) and the Chrysler bottle of friction modifier has to be installed for Trac-Lok rear ends. How often has the diff fluid been changed? |
#3 |
Thanks for the reply, all was completed about 20,000KM ago, main question is have others had issues with the KJ tranny and rears. I do not recall seeing any and visit here often.
#4 |
If you are trailering, Chrysler specifically states that a synthetic gear lube on 75W-140 to be used.
I would consider changing diff oil again if you did not use synthetics. I Normally change the diff oil every 25,000km with synthetic. You did not answer if you have a Locking Trac-Lok differential, that absolutely needs friction modifier added as well. If you do have Trac-Lok those clutches don't last all that long 40,000km..aprox before mine went. Does anyone have the Chrysler Part # for that small bottle/tube of friction modifier handy, I need some.. Last edited by LibertyTC; 11-20-2009 at 08:02 AM.. |
#5 | |
But I did come up with this: Chrysler 4318060 Friction-Modifier, if you want only Chrysler. |
#6 |
Chrysler Friction Modifier
Thanks Valvestem,
Heading out for shopping now....why does my weekly shopping list always contain something for the KJ?![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
