transmission issues...help! - JeepForum.com
post #1 of 3 Old 05-16-2013, 10:51 PM Thread Starter
Stevusprime
2004 KJ Liberty
My 04 liberty has funny shift points and sometimes while from a stop takes a while to catch...i had it go into limp mode just the other day so i took the battery terminals off and held them together and it has been shifting ok..I have had the tranny rebuilt at a shop, but it still acts up...what can I do to further investigate?
Could it be maybe they used the wrong fluid, it seems over filled a little too.
It had a new computer (mounted on d/s wheel replaced back in 09)are they a common problem?
Stevusprime is offline
post #2 of 3 Old 05-17-2013, 06:39 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2006 XK Commander
If you had it rebuilt then the shop that did it has some culpability for its bad behavior if the rebuild came with any kind of warranty. I would bet the shop used the wrong transmission fluid - they should have used ATF+4. No matter what they tell you that is the ONLY fluid appropriate for the 42RLE transmission.
Bob
SOLD: Highly modded '03 KJ Liberty Renegade
- Current Jeeps '06 XK Hemi Limited - OME HD Springs/Bilstein 4600 shocks, AiRaid CAI, Billet Technology catch can, SuperChips tuner, RHR Nav upgrade, 1.5" wheel spacers. '16 Renegade, Removable roof, auto headlamps/wipers, heated seats/steering wheel
TwoBobsKJ is offline
post #3 of 3 Old 05-20-2013, 06:57 AM Thread Starter
Stevusprime
2004 KJ Liberty
It was acting up before I had it rebuilt but it did not solve the problem at all...I went to the junk yard and pulled input/output sensor from an 01 jeep grand cherokee with the same part numbers...I haven't had a chance to out them in yet.
I think its more of a computer or ground issue than tranny, I read on another forum to shut the car off while driving and start it back up and it will shift through the gears and it works for now...any other ideas?
