Transfer case swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Transfer case swap
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201FS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 06-04-2014, 07:06 AM   #1
ejschultz
ejschultz's Avatar
Transfer case swap
I believe I've posted about this KJ before, but my cousin bought an 02 KJ with a bad 242. At first I thought it may have been the chain, but I believe it's the planetary gear setup for the full time 4 wheel drive. I sourced a low mileage (under 100k) 242 for her. It came from an 03 KJ. I'm going to make the assumption that these cases should be a direct swap and that no changes occurred between the two years. I'm a ZJ guy and every single year is different one way or another, so I guess I just want to make sure. What's all involved with dropping a transfer case on a KJ? I'm used to just pulling two driveshafts, disconnecting some linkage and sensors, and 6 nuts on studs. Does the crossmember have to come down to get it swapped? I haven't looked much underneath the Jeep so I'm not feeling too comfortable right now about the swap. If the actual work is as easy as I'm used to, then it shouldn't be a problem. I guess I just want to get my ducks in a row before I knock this out for her.
97 ZJ - 5.2L, 242, 4" IRO lift w/short arms & adj. TBs, JKS Discos/BPEs, DT3000s, Aussie'd 44A, sliders, OEM skids/hooks/hitch, 31" Duratracs on 15x8s
14 JKU Sport S - Stock
Build
ejschultz is offline   Reply With Quote
Unread 06-04-2014, 01:40 PM   #2
remmons
Some assembly required.
2002 KJ Liberty
Someone with more knowledge than we will chime in and provide the correct answer, but in the mean time, are both KJ's automatic? The reason that I ask is that the '02 has the 45RFE Auto as where the '03 had the 42RLE trans, so You might want to take a look at the transfer case Input and see if they have the same shaft size and spline count, and take a look at the Adapter plate and see if the bolt holes all line up and are clocked correctly as well.
2002 Liberty Sport 3.7. 2.5" lift.
http://www.jeepforum.com/forum/f12/i...t-case-989208/
remmons is offline   Reply With Quote
Unread 06-04-2014, 05:05 PM   #3
Leeann_KJ
2005 KJ Liberty
Yup, both driveshafts, the linkage and sensors, and 6 nuts on studs. At least, that's how it is on my '05. Hit the studs/nuts,with PB before you start on the sensors and linkage and be careful with the plastic parts on the linkage as they get a bit brittle with age.
I'm with remmons, though: make sure the driveshaft connections are the same before you dig in (I think they are, since driveshaft parts lists the replacement CV head for '02-'07 KJs).
Leeann_KJ is offline   Reply With Quote
Unread 06-05-2014, 01:41 AM   #4
ejschultz
ejschultz's Avatar
Thanks! Can anyone attest to the cases being interchangeable between 02 and 03? I wasn't aware the transmissions were different. That doesn't necessarily mean it won't work though. It may require an input swap or something. On ZJs, any 96 to 98 transfer case can be used with any 96-98 transmission (be it the 42RE, 44RE, or 46RE).
Build
Unread 06-05-2014, 11:22 AM   #5
remmons
2002 KJ Liberty
Check with the Input Gear, It's the only component that you should be worried about as that everything else should be the same.
Unread 06-05-2014, 07:06 PM   #6
ejschultz
ejschultz's Avatar
Cool. I'll check when I get the other one out, I guess.
Build
Unread 07-01-2014, 07:01 PM   #7
2002Jeepdad
2002Jeepdad's Avatar
I'm up against the same thing now.
How did you make out? are the transfer cases & hook ups the same in the 2002 & 2003?
Live Long, Jeep Naked!
2002Jeepdad is offline   Reply With Quote
Unread 07-02-2014, 09:02 AM   #8
remmons
2002 KJ Liberty
Have any updates on your transfer case swap?
Unread 07-03-2014, 03:32 AM   #9
ejschultz
ejschultz's Avatar
I haven't done it yet. I was going to do it last weekend but ended up working all weekend. I'm going to be out of town for a few weeks starting Sunday so it's not going to get done probably until August now. Luckily, for my cousin, 2 wheel drive works. I have a little bit of time before the weather starts getting cold and snowy again; hopefully, it doesn't take me that long.
On another note, I did research the input gear between an 02 and an 03 KJ. They appear to have the same part number. That'd be sweet if the swap was a nice and easy swap. I'll update you guys when I finally get around to doing the swap. I appreciate your help.
Build
Unread 07-03-2014, 08:43 AM   #10
remmons
2002 KJ Liberty
LOL, I understand the work thing, my basket-case project sometimes sat for months because of work, or a shortage of funds. Keep us posted when you get to that point, we like to hear success stories, plus your information will help others down the road who will be doing the same thing.
Unread 07-03-2014, 12:11 PM   #11
The_Dealer
2003 KJ Liberty
Not really a thread jack, but when looking for a replacement tc, what do you need one from? For example if I have an 03 3.7 with 42rle, can you use an 05 3.7 tc? Just wanting to know what's interchangeable and what isnt.
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline   Reply With Quote
Unread 07-03-2014, 01:55 PM   #12
Leeann_KJ
2005 KJ Liberty
Yep. Looks like '02-'07 all interchange, if the above info is correct (and I think it is).
Unread 07-07-2014, 10:40 AM   #13
remmons
2002 KJ Liberty
I will agree. I just finished doing some searching for the input gear and it looks like that they are all the same. Here is only one of the several examples that I have found.
Crown Automotive NP231 Transfer Case Input Gear 4798113
Part Number: CRO4798113
Item Description
Fits 1997 to 2000 TJ Wrangler
Fits 1994 to 1995 YJ Wrangler
Fits 1997 to 2001 XJ Cherokee
Fits 1994 to 1997 ZJ Grand Cherokee
Fits 2002 to 2007 KJ Liberty
NP231 transfer case
23 spline
Approximately 4.75 in length"
Edit: I just surfed the web with the key words "2002 Liberty NP242 Input Gear" and I keep getting these same results, so I would highly recommend calling Chrysler/Jeep and see for sure what the compatibility is.
Input Gear 1997-1998 Jeep Grand Cherokee ZJ 1994-2001 Jeep Cherokee XJ
Unread 07-07-2014, 10:52 AM   #14
The_Dealer
2003 KJ Liberty
So the only difference would be the output shaft spline count? I have a np231 from a tj with an sye I will swap in place of my worn out 242 if that's the case
My build
Unread 07-07-2014, 11:19 AM   #15
remmons
2002 KJ Liberty
That is something to search more into. At this point I would say that they are not compatible, but this was for the XJ Cherokee and not for the Liberty KJ. When I had adapted a NP242J from a 1988 XJ into my 1988 YJ, I wanted to do the slip yoke eliminator, but the only way to do it was either from one of a handful of suppliers or to do a hack-N-tap. Here is a great write up regarding the SYE on a NP242.
http://www.jeepforum.com/forum/f11/o...l-read-426483/
