Transfer case gone? - JeepForum.com
post #1 of 6 Old 04-06-2014, 10:04 AM Thread Starter
js522045
Transfer case gone?
I think my transfer case is gone, looking for some second opinions before I rip it out.
For quite some time it has made some noise in 4x4 like a gear is slipping. Then yesterday I lost 4x4. I can move the shifter into 4 hi, but it doesn't engage, and I can't seem to pull it into 4lo at all. I can still drive it around in 2wd though.
2003 liberty
2.4L, 5 speed
4x4 shift on floor, 2wd, 4hi, 4lo
js522045 is offline
post #2 of 6 Old 04-06-2014, 12:34 PM
streetglideok
2005 KJ Liberty
Before I would condemn the t-case, I would do some investigating. Best thing to do would be get all four wheels off the ground, safe and securely and engage the 4wd. Put it in first, let the clutch out and see if the wheels turn. Confirm visually the front driveshaft turns. My first guess is your intermediate shaft and cv axle splines are worn, and letting the one shaft slip inside the other. Makes a gear like noise and with open diffs, will behave like you lost 4wd.
streetglideok is offline
post #3 of 6 Old 04-06-2014, 07:39 PM Thread Starter
js522045
thanks, ill check that out first
js522045 is offline
post #4 of 6 Old 12-01-2015, 07:04 AM
bankrep
2004 KJ Liberty
my 4wd shifter bushing had fallen off the t/c and I was unable to shift past neutral on 4wd shifter. If the bushing is your problem, be sure to put t/c in 4w lo and pull shifter to 4wd lo to line up to install bushing.
bankrep is offline
post #5 of 6 Old 12-02-2015, 09:56 PM
KodiakKJ
2003 KJ Liberty
Other than checking the bushing like bankrep said, wouldn't this seem almost like the linkage is loose or disconnected?
KodiakKJ is offline
post #6 of 6 Old 12-04-2015, 01:55 PM
u2slow
2005 KJ Liberty
When the NP207/208/231/241 cases fail it often results in 2wd skipping/slipping too. Dealing with this in my Ramcharger at the moment.
I would look in the front diff first. On our KJ, I found the CV-to-intermediate shaft spline partially stripped.
u2slow is offline
