Trailer Wiring - Problem - JeepForum.com
post #1 of 5 Old 07-23-2007, 01:52 PM Thread Starter
Threejeeps
I had my 2004 Liberty wired to tow behind our RV about a year ago. This weekend I bolted on the MOPAR hitch and plugged in the module for the trailer hitch wiring. On the trailer - the brake lights, turn signals and four-ways all work, but running lights (when headlights are on) do not work.
My guess at the moment is when they wired my Liberty to be towed behind the RV they snipped or disconnected wiring somewhere (perhaps behind the tail light lenses). I am hoping there is an easier answer out there.
Any suggestions?
Much thanks.
Threejeeps
'05 Commander 5.7L Hemi
'04 Liberty 3.7L V6
'89 Wrangler 4.2L Straight 6
Middletown, NJ
Threejeeps is offline
post #2 of 5 Old 07-23-2007, 03:11 PM
chadlyt
2006 KJ Liberty
I guess you didnt have the add-a-bulb on the libby done then and they were wired direct? either case, they may have snipped the yellow (i think?) wire or just plain disconnected it.
chadlyt is offline
post #3 of 5 Old 07-24-2007, 08:55 PM Thread Starter
Threejeeps
Thanks, although I am not sure I completely understand. When they wired the Liberty to tow behind the RV - they added several diodes behind one of the rear tail lights. I was going check that next. Is that where the "yellow" wire you talk about may be located? What's an "add a bulb?" The tow hitch wiring harness is a plug and go set up - no splicing involved. It plug into the rear wiring harness behind the right rear interior trim panel.
Really, appreciate the ideas.
Threejeeps
'04 Liberty 3.7L V6
Middletown, NJ
post #4 of 5 Old 07-25-2007, 07:13 AM
chadlyt
2006 KJ Liberty
I used a Blue Ox add-a-bulb kit. Meaning, you do not use any of the Jeeps internal wiring, you add your own from the front of the jeep to the rear where you add a bulb in the tail light housing.
There have been many reports of problems with diode wiring in jeeps, hence the add-a-bulb solution.
I'll be back later with hopefully a few more answers for you.
chadlyt is offline
post #5 of 5 Old 07-25-2007, 12:18 PM Thread Starter
Threejeeps
I am with you now on the "add a bulb" approach. As you can tell, the folks at Camping World use the interior wiring for my Jeep. ANY additional information would be helpful. It seems so damn odd that I have all but the running lights on the trailer. Much thanks!
Threejeeps
'04 Liberty 3.7L V6
Middletown, NJ
New Member with trailer wiring problems gpschmidt KJ Liberty Forum 7 08-05-2008 02:17 PM
2006 OEM Trailer wiring harness chadlyt KJ Liberty Forum 1 10-05-2007 07:52 AM
Trailer Wiring help Dustin07 KJ Liberty Forum 6 08-21-2007 02:54 PM
Trailer brake wiring CM CRD KJ Liberty Forum 5 09-14-2006 03:12 PM
Trailer hitch wiring dadejeep KJ Liberty Forum 0 02-06-2006 02:22 PM
