Trailer brake wiring - JeepForum.com
post #1 of 6 Old 09-14-2006, 10:14 AM Thread Starter
CM CRD
I have a 06 CRD and it didn't come with the trailer hitch. I installed a class III hitch and now I'm working on the wiring. I chose to go with all aftermarket components for this project. I bought a T-One connector which will take care of my basic trailer light wiring. That's about a 20 minute job. Now I have to run a #10 red, #10 white and #12 blue up to the front of the vehicle to interface with my brake controller and battery. From what I've gathered from reading up on several forums there is no factory wiring installed for in my Jeep. I don't have the EVIC module (for some reason if you do then you have the trailer wiring from the factory). Does anyone know if the 30amp trailer tow fuse under the hood goes anywhere? I plan to use that fuse but I don't want to tear into the fuse panel if there is already a wire coming off it that I can use. Also, is that fuse meant to be used for the brake controller or for the 12V aux power. I know how to wire brake controllers and trailers, I just want to do it the right way and the easiest way.
Thanks
CM CRD is offline
post #2 of 6 Old 09-14-2006, 12:11 PM
BVCRD
Thanks
I have read that there is a wire behind the drivers side kick panel that has a tab on it marked trailer brakes.
2006 Jeep Liberty Sport CRD
BVCRD is offline
post #3 of 6 Old 09-14-2006, 12:28 PM Thread Starter
CM CRD
It's wierd that there is no mention of any wires for tralier brakes in the manual. I'll take a look under that panel anyway.
thanks
CM CRD is offline
post #4 of 6 Old 09-14-2006, 12:58 PM
BVCRD
thanks
You might try doing a search for the wire in this forum's search tab. I think it was on here a while back where a guy had pictures of it. It was behind a couple clusters of wires, by itself, and I believe it was blue or maybe purple, but it had a piece of tape on it and it was clearly marked.
BVCRD is offline
post #5 of 6 Old 09-14-2006, 01:40 PM
Amarony
Answer should be in here
http://www.jeepkj.com/forums/viewtopic.php?t=1691
-Dave
2005 Dark Khaki Renegade
Amarony is offline
post #6 of 6 Old 09-14-2006, 02:12 PM Thread Starter
CM CRD
Looks like I have to run some wires. Not a problem, just wanted to make sure before I started. Thanks guys.
CM CRD is offline
2006 OEM Trailer wiring harness chadlyt KJ Liberty Forum 1 10-05-2007 06:52 AM
Trailer Wiring help Dustin07 KJ Liberty Forum 6 08-21-2007 01:54 PM
Trailer Wiring - Problem Threejeeps KJ Liberty Forum 4 07-25-2007 11:18 AM
Trailer hitch wiring dadejeep KJ Liberty Forum 0 02-06-2006 01:22 PM
Electrical trailer wiring harness psujeeperman02 KJ Liberty Forum 9 07-05-2005 02:50 PM
