-   KJ Liberty Forum (http://www.jeepforum.com/forum/f28/)
-   -   trac loc (http://www.jeepforum.com/forum/f28/trac-loc-1536028/)
mike6114 06-13-2013 11:58 AM
trac loc
I recently purchased a 2003 liberty, I got a great deal or did I? I paid 7300.00. the jeep has 46000 miles on it and is great shape. I did a carfax on it, zero accidents or problems. any thoughts? I'm about to do a bunch of routine maint. because I don't know the exact history of what has or has not been done over the years. My question is how do I tell if it has trac loc or not? I do not see a tag on the rear axle, is there any way to tell in the vin or another way? Thanks
KLT88YJ 06-13-2013 02:14 PM
Do you know if it has the off-road package or towing package from the factory? If so you've got your self a tracloc. Only use the Chrysler antifriction modifier through jeep or a driveline shop as your additive.
mike6114 06-13-2013 02:39 PM
I don't think it has a tow package it did not come with a tow hitch, or wiring. however it does have skid plates to include the gas tank, plus two front tow hooks and one driver side rear hook.
KLT88YJ 06-13-2013 03:48 PM
It should have the off road group then.
ppap 06-13-2013 06:01 PM
Jack the rear of the vehicle so the rear wheels are off the ground. Put the transmission in neutral and manually spin one of the rear wheels. If both wheels turn in the same direction, it has a limited slip carrier. If they spin in the opposite direction from each other, its an open carrier. Note that this does not always apply to mechanical lockers. You can also remove the cover and look into the carrier. If it has an open carrier, all you'll see is the spider and side gears inside the carrier housing. Plenty of pictures on the internet as to what it looks like.
mike6114 06-13-2013 06:28 PM
thanks that sounds easy enough if they spin the same direction it has trac loc.
DaveJKJ 06-13-2013 06:46 PM
Just look at the axle tag if it is still there. It should be on the drivers side axle tube and say either "open" or "trac-loc" and the gear ratio. Or just get a "build sheet". You should have one anyway.
Luke09 06-13-2013 08:13 PM
Read Dave ... Jeez! ;)
DaveJKJ 06-14-2013 03:48 PM
ooooops.....my bad Luke...LOL
Luke09 06-15-2013 11:54 AM
I'll be here .. to catch the one mistake you make all year :D
mike6114 06-19-2013 09:45 AM
I received a build sheet from jeep, which indicates the vehicle was built with "DHNS" command trac is this trac loc?
tommudd 06-19-2013 09:47 AM
No that is the transfer case you have
The time now is 08:31 PM.
