Towing capacity - JeepForum.com
post #1 of 7 Old 09-23-2013, 09:10 PM Thread Starter
Komodo
Towing capacity
The specification on my Jeep liberty 2005 says that I can tow 5000 pounds. Does this include then cargo in the trunk of my jeep?
Komodo is offline
post #2 of 7 Old 09-23-2013, 10:55 PM
jbarthol
2005 KJ Liberty
5000lbs with a towing package. If you don't have the towing package than its 2000lbs I believe.
Sent from my Samsung Galaxy S3 using JeepForum
jbarthol is offline
post #3 of 7 Old 09-25-2013, 04:34 PM
USPLiberty
I think that the listed cargo capacity is 400lbs, so it means that you can tow something that is up to 5000 pounds with another 400 max inside the car. You jeep will be really slow with that much weight.
USPLiberty is offline
post #4 of 7 Old 09-25-2013, 10:10 PM
Bmach
People do not think that a Liberty can tow much but they are wrong, IMO. I have towed a HTT weighting 3560# and I would get anywhere from 11.5 to 15.2 mpg with it. I would drive at at around 63mph and slow to around 50 mph on some hills.
Bmach is offline
post #5 of 7 Old 09-27-2013, 09:09 AM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
I don't recall the exact number but in your owner's manual will be the Gross Combined Vehicle Weight Rating number which includes the total weight of the trailer plus the weight of the Jeep including cargo. We are not to exceed that GCVWR number.
That said, the KJ is a very capable tow vehicle when properly equipped. The challenge isn't getting the trailer and the KJ moving - the issue is stopping the rig. If you're towing more than 2500lbs or so you should have trailer brakes and and a brake controller - which means you should have the 7-pin round connector.
"It ain't the going but the slowing when towing..."
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is online now
post #6 of 7 Old 09-27-2013, 11:12 AM Thread Starter
Komodo
This is the specs of my Jeep. (3.7-Liter Engine Automatic)
3.7-Liter Engine - Automatic
Axle Ratio (lbs.) 3.73
GVWR (lbs.) 5600
GCWR (lbs.) 5600
42RLE 7400
Multi-speed auto 10,100(b)
GAWR Front/Rear (lbs.) 2750/3150
Curb Weight, est.(a) (lbs.) 4115
Max. Tongue Weight(b) (lbs.) 750
Max. Trailer Weight(b) (lbs.) 5000 (with the towing package)
Max. Payload(c) (lbs.) 1150
Max. Cargo(d) (lbs.) 400
My trailer has a braking system that is connected to my Jeep brakes. Whenever I brake, the trailers brakes are also applied.
The trailer weighs 3950 pounds.
Komodo is offline
post #7 of 7 Old 09-27-2013, 12:15 PM
Bmach
My combined was10,100 that was for a 2008.
Bmach is offline
