Total electrical failure - JeepForum.com
post #1 of 4 Old 01-14-2014, 02:39 PM Thread Starter
darcstampede
2006 KJ Liberty
I went to start my jeep yesterday morning and my remote unlock wasn't working, used the key to open the door like a primitive savage and no dome light or any sort of electrical going on in the car. Disconnected the battery and reconnected it and it started but idles rough. The battery is only a year old, and I just replaced the 02 sensors and the spark plugs which cleared up some previous error codes, but now I'm getting random multiple cylinder misfires and this problem with the electrical going completely dead. Today it started up fine but on my way home from work my dashboard lit up and my radio cut out, shortly before the electrical shut off on me in the middle of the road, and with no electrical I couldn't turn my hazards on. Any ideas what's causing this?
Thanks
darcstampede is offline
post #2 of 4 Old 01-14-2014, 06:45 PM
02blue
2005 KJ Liberty
Sounds alot like the battery again. Connections/ground okay?
02blue is offline
post #3 of 4 Old 01-14-2014, 06:50 PM
Bnova
2006 KJ Liberty
I would suggest checking to see that you have good battery cables, battery post clamps and good clean tight connections at the cable ends and clamps. If the cables look like they've got any white powder down inside the insulation I'd replace them with new cables. Just a thought and that's where I'd go first just to vertify. And you said your batt was new a year ago, it is not unthinkable that it is toast already. I would also rule that out right away too, have it checked.
Bnova is offline
post #4 of 4 Old 01-15-2014, 01:36 AM
Billwill
2002 KJ Liberty
You will need to measure the wiring from the battery through the fuse boxes, ignition switch etc. using a voltmeter. Obviously first check all fuses in the fuse box under the hood and inside the cabin. First check that your battery is not toast as stated above...try a different battery!
A fused diode in the alternator could cause the battery to run flat rapidly.
Download the 2006 KJ Service manual here...includes circuit diagrams:http://www.colorado4wheel.com/manuals/Jeep/KJ
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
cylinder , electrical , misfire
