Torx bit size to remove tie downs - JeepForum.com
post #1 of 16 Old 06-28-2006, 05:15 PM Thread Starter
garyblais
I need to replace/remove the carpet in the cargo area (spilled pesticides) and the dealer told me to use Torx bits which I had already tried on the tie downs which hold the carpet down. A T10 fits in the nut but won't turn it and a T15 is too big. There are no bit sizes between T10 and T15, at least not to my knowledge. Answers.com says there are some variants like Torx PLus and Torx TR which may be the problem but I can't be sure. Short of going to the dealer and putting up with that hassle just to loosen a few nuts, I wanted to give you folks a chance to weigh in. Anybody know how to loosen these bad boys?
garyblais is offline
post #2 of 16 Old 06-29-2006, 08:29 AM
BVCRD
When I used to ride hogs, I had a thing that would torque down a screw big time. You would put the bit in, then turn it slightly when you struck it with a hammer. The same thing only in reverse to loosen it. Man it really got the screws of the case on tight. More than just with a screw driver alone. Maybe try to get your hands one one of these tools.
2006 Jeep Liberty Sport CRD
BVCRD is offline
post #3 of 16 Old 06-29-2006, 08:38 AM
rob92xj
1992 XJ Cherokee
Yeah it's called a torque driver, thedy do work really good.
Sorry I have not had to remove the rear carpet in a KJ yet and all I have at work so far is mini vans loaded up with recalls. If I do get a KJ in I'll find out what torx bit fits for you.
rob92xj is offline
post #4 of 16 Old 06-29-2006, 10:06 AM
Tom_with_a_Drea
Tom_with_a_Drea's Avatar
I have my torx (I bought to install my cargo organizer) in the Jeep. Will post the size after lunch.
I don't recall them bolts being too terribly tight.
'05 CRD Silver Sport
As Delivered:
Sunroof, Tow, 700mi
Warranty:
EGR (2), TC & Pump, EGR FCV
After-market:
Guages (5), PIAA duals, Hitch & side lights,
AeroTurbine, Fumoto, 3.7L Airbox, Revos, Steps,
Cargo Tray, Hitch Rack, Bike Rails, & Slush Mats
Tom_with_a_Drea is offline
post #5 of 16 Old 06-30-2006, 11:03 PM
Tom_with_a_Drea
Sorry I abandoned you, I forgot.
The bolts were a T30 torx. Hope that helps.
As Delivered:
Sunroof, Tow, 700mi
Warranty:
After-market:
post #6 of 16 Old 07-01-2006, 07:54 PM
corwyyn
2003 KJ Liberty
No torx bits, they are riveted in place. I pulled the carpet on mine a while back to try and take care of some RFI on my ham radio and thought they were torx. Just drill them out and replace them when you are done.
corwyyn is offline
post #7 of 16 Old 07-01-2006, 10:24 PM
Tom_with_a_Drea
I might have been premature in my post, or I might have mis-read.
The T30 torx are for the two tie-downs in the rear cargo area, used to mount the organizer. If there are additional carpet tie-downs then my info is irrelevant. Sorry.
As Delivered:
Sunroof, Tow, 700mi
Warranty:
After-market:
post #8 of 16 Old 07-03-2006, 07:35 AM Thread Starter
garyblais
Please explain the "drilling out" part. I'm not mechanically inclined.
post #9 of 16 Old 07-03-2006, 07:40 AM Thread Starter
garyblais
Well if they are Torx fasteners they aren't regular Torx fasteners. I tried a T10 and it fit in the nut but wouldn't turn it so a T30 would definitely not fit. There's a new Torx bit called Torx Plus (http://www.answers.com/torx which has a different interior design. It might be this I'm dealing with or a rivet as corwyyn maintains.
post #10 of 16 Old 07-07-2006, 04:33 AM
corwyyn
2003 KJ Liberty
If I read you correctly you are talking about the two metal plates in the rear corners of the cargo area - they have a depression with a crossbar that you can use for a bungee cord or whatever and they sit right on the carpet. The two round screw-looking things that hold them down should be rivets. To make sure they are rivets (before you start drilling), lie down under the rear end and shine a flashlight up at the area where the plates mount. You should see what look like short metal tubes sticking down - these are the backsides of the rivets. To remove rivets simply get a drill bit slightly larger than the opening in the top (where you would put a torx bit if it was one of those screws) and drill down thru the rivet; if I remember correctly I used a 3/32" bit. The rivets are aluminum, so just go slow and steady. Once done the plates should come right up. To re-install you'll need a rivet gun and replacement rivets. These can be had at any decent hardware/home improvment store.
corwyyn is offline
post #11 of 16 Old 07-07-2006, 11:04 AM Thread Starter
garyblais
Thanks!
I'll try it today, the smell is driving me nuts.
post #12 of 16 Old 06-09-2007, 02:17 PM
chrispitude
Did you ever figure out how to remove these tie-downs? We just broke a bottle of wine in the back cargo area (white, thankfully) and it just baffles me that Jeep riveted these things in place to save a few cents. It's a Jeep... wouldn't you plan ahead to allow people to clean the carpets?
Edit: My buddy made a good suggestion - cut the cargo carpet around the tiedowns, then use velcro on the underside of the padding and the floorpan to keep the mat from sliding around. Has anyone tried this, or perhaps replacing the tiedown rivets with more suitable fasteners?
- Chris
1995 BMW M3, 2005 Toyota Tundra regular cab V8 4x4, and the wife has a 2006 Liberty Sport CRD which I like better than both!
chrispitude is offline
post #13 of 16 Old 06-14-2007, 12:13 PM Thread Starter
garyblais
SOlution
I ended up doing what your friend suggests but I didn't replace the carpet. I bought a hard rubber mat made for the Liberty. It has holes for the tie downs and has worked out well. I don't remember where I got it though but try Goggle.
post #14 of 16 Old 06-15-2007, 07:26 PM
chrispitude
Hi all,
So what's the trick to loosening the plastic trim pieces along the sides that overlap the carpet edges? I've pulled the carpet out to clean it, but it would be much easier to reinstall if I can pull the trim panels up/out to properly tuck the carpet back in. Heck, if I can move the trim panels, I might be able to clean up the mess behind there too.
- Chris
post #15 of 16 Old 11-24-2013, 10:57 AM
ajlugo
just cut around the carpet is not wort the work of riveting the cargo hooks again just cut under the edge make a clean cut men i just took on out then i notice it was not hard to take out cutting the carpet hope this help
ajlugo is offline
How do you remove the tail lights? Wrangler98 KJ Liberty Forum 5 02-19-2011 11:26 AM
Remove coolant RBPARROT KJ Liberty Forum 7 10-23-2009 07:57 PM
How do you remove the IAC in a 2004 Liberty jakewire KJ Liberty Forum 1 10-03-2008 09:30 PM
How to remove shifter cover? spamloverman KJ Liberty Forum 10 04-08-2007 07:13 AM
Can I remove the Main Engin Fan and.. SS-Virus KJ Liberty Forum 31 06-08-2006 05:12 AM
