Tires for 17" - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Tires for 17"
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINERô UV Permanent DIY Roll On Bed Line
Unread 02-13-2015, 11:22 AM   #1
Dave L
2005 KJ Liberty
Tires for 17"
Okay I've searched a lot on this and the answers are sort of all over.
I know the 17 inch rim is pretty much useless and not known for its variety of available tire choices.
I have a 2005 Limited running the stock size 235/65R17. I'd like to find a decent looking aggressive tire for all around use. I hated the Wrangler HP OEM, currently using destination LE, which looked "Egh" and didn't wear very well.
Without making any vehicle mods does anyone have any good suggestions or photos of what you are running?
Thanks
Dave L is offline   Reply With Quote Quick reply to this message
Unread 02-13-2015, 06:18 PM   #2
95BadBoy
What is the measurement from the middle of your hub to the bottom of your wheel well? Just wondering how much sag you are already dealing with on the suspention.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded
FS or FT (2) JK Rubi 17" Moab Rims - really nice shape
Need JK Rear Spare tire bracket for project
95BadBoy is offline   Reply With Quote Quick reply to this message
Unread 02-13-2015, 06:37 PM   #3
Dave L
2005 KJ Liberty
I'll give it a measure in the am when hopefully its warmer than -11!!!
Unread 02-14-2015, 01:16 PM   #4
ACM423
2006 KJ Liberty
Nitto Terra Grappler G2s run 235/80R17. Theyre a very nice tire, if they fit I highly recommend em. I run 265/70R17 and love em.
ACM423 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2015, 01:48 PM   #5
Dave L
2005 KJ Liberty
Are you lifted or stock?
Unread 02-14-2015, 01:56 PM   #6
ACM423
2006 KJ Liberty
I run a 3" RC Lift right now with minor rubbing in the front. Im upgrading to a 4" JBA lift to eliminate all rubbing.
Unread 02-14-2015, 02:06 PM   #7
Dave L
2005 KJ Liberty
Nice ride! Not sure I want to invest in a lift at this point.
95BadBoy, I have about 17.75" from hub to highest contact point of the wheel well trim(The well itself is much deeper),
Rear is around 18.5"
Unread 02-14-2015, 02:32 PM   #8
DaveJKJ
2005 KJ Liberty
My stock OEM size was also 235/65/17 just like yours. It is a PIA for tire options. You should also be able to run a 245/65/17with stock height without rubbing but that would be it so you could look for tire types in that size also.
Anything bigger and you will need to be lifted to have clearance. Once mine was lifted I had more options.
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline   Reply With Quote Quick reply to this message
Unread 02-14-2015, 03:03 PM   #9
ACM423
2006 KJ Liberty
This should help you out a little for choosing a wheel size. This is a chart done by JBA.
