Timing question - JeepForum.com
post #1 of 2 Old 07-17-2017, 10:00 AM Thread Starter
CB4_D
Timing question
I'm working on a 3.7l liberty. Lined up my timing chain per the service manual. Rotated the crankshaft clockwise several times to verify things looked good when I noticed the witness marks on the chains would not line back up with the "L" & "R" marks on the cam' s as well. For that matter neither on the crankshaft or idler as when it was initially set. Should I be concerned about this or just rely on the cams being at the 12 and crank at the 6 at the normal 2:1 ratio?
CB4_D is offline
post #2 of 2 Old 07-18-2017, 02:20 PM
Sloepoke
Last one I did I didn't pay any attention to links on timing chains . Made sure crankshaft gear mark was at 6 , idler gear mark was at 12 & V6's on both cams were at 12 . Runs fine .
Sloepoke is offline
