Tie rod issues - JeepForum.com
post #1 of 5 Old 07-03-2012, 12:09 AM Thread Starter
jeepkj617
2008 WK
Tie rod issues
Went to get reinspected today.
Rejected due to:
"Left front tie rod issue - very loose, maybe not tie rod"
misaligned headlights
top brake light out
I went and realigned my lights and replaced the brake light bulb for $4 at advance auto which leaves... the tie rod.
Should I use stock or aftermarket replacement parts and how difficult is the repair?
"What do you mean it don't work? Just hit it with a bigger hammer!"
Thinking about buying a Cobra® 29-LTD 2-Way 40-Channel CB Radio. Anyone have install/antenna suggestions?
jeepkj617 is offline
post #2 of 5 Old 07-03-2012, 10:57 AM
tjkj2002
2002 KJ Liberty
The outer tie rod end is easy to replace,the inner tie rod end is more difficult.Eitherway you will need a alignment after putting on a new tie rod end,no way around it and counting threads get's you close but it will be out of alignment.
tjkj2002 is offline
post #3 of 5 Old 07-03-2012, 11:02 AM Thread Starter
jeepkj617
2008 WK
ok, i need an alignment anyway - plus if I can get it close ish, the place I bought my tires from last year owes me a free alignment this month anyway.
Looks like the ball joint on the outer drivers side is shot - I'm replacing both the outers (left and right) while I'm under there
Also, are the moog tie rods ok?
post #4 of 5 Old 07-20-2013, 04:15 PM
countrygirl1536
I was just wondering before you had it checked out to see it was the tirod if the Jeep was making any noises? My Jeep has this constant clicking sound (sounds like rock in tire) but have had new tires, only when Jeep is in motion do I hear this clicking noise that drives me nuts. Sounds like front left side. Thanks.
countrygirl1536 is offline
post #5 of 5 Old 07-20-2013, 06:03 PM
tommudd
2004 KJ Liberty
Tie rod end will not give a clicking sound
Start checking the rear boot on the front driveshaft, the CVs etc
04 KJ WITH JBA 4 INCH COILOVER LIFT
03 KJ WITH JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
4wd issues benlee248 KJ Liberty Forum 3 12-13-2011 03:50 PM
Key Issues m1a1mg KJ Liberty Forum 0 10-28-2010 08:40 PM
05 JK A/C Issues JeepRestoration KJ Liberty Forum 0 08-01-2010 09:36 PM
A/C Issues teecro KJ Liberty Forum 4 05-13-2009 08:36 PM
Issues LIBAR8R KJ Liberty Forum 2 10-04-2006 07:57 AM
