Thinking Of Buy A 2002 KJ - JeepForum.com
post #1 of 8 Old 05-08-2012, 01:11 PM Thread Starter
bill-pat
What should I know before I buy one?
Any kind of special repairs these jeeps require?
What should I look out for?
Is there a sticky about their known problems that I could read?
Thanks for any input
bill-pat is offline
post #2 of 8 Old 05-08-2012, 01:23 PM
Lafever25
I would just read over threads of people having issues... I picked up an 02' Renegade back in march, so far had to change the plugs, leaky radiator, water pump, clean throttle body, change TPS sensor, camshaft sensor, and other sensor (air) from throttle body... It's still having troubles starting up or after a fill-up... New battery, did all my research and still can't get around this starting issue... My next try is fuel system, replace fuel filter, check fuel pump, injectors, and of course the fuses...
Fuel efficiency, I get around 13-16 mix driving. It's a little better than my 07' frontier which gets 12-15mpg.
Lafever25 is offline
post #3 of 8 Old 05-08-2012, 01:28 PM Thread Starter
bill-pat
Thanks for the info.
Did you do all that work yourself?
Is there a thread you started for help with the hard starting?
Edit: I read this about the hard starting:
Fuel pump: The engine my crank several seconds before starting due to loss of fuel pressure caused by a bad check valve in the fuel pump assembly. (2002)
Here is the link:
http://consumerguideauto.howstuffwor...-liberty-2.htm
bill-pat is offline
post #4 of 8 Old 05-08-2012, 03:15 PM
All3Sports
2004 KJ Liberty
02 being it's first year of production has its ups and downs, nothing too serious just window regulators but the 02 and early 03's have the better 45RFE tranny vs. the now 42RLE. Just make sure it has been taken care of and has the proper service records and that everything functions correctly like try rolling the windows up and down to see if there is problems with a regulator.
Here's a decent overview and review of the 02 Libby:
http://www.rockcrawler.com/reviews/j...2002/index.asp
And if I remember correctly the NV242 is the better, full-time transfer case over the NV231 part-time t-case.
02 KJ Renegade - Totaled....
04 KJ Limited - OME 927/948 General Grabber AT2 247/75/16
All3Sports is offline
post #5 of 8 Old 05-08-2012, 05:26 PM
tjkj2002
2002 KJ Liberty
The 2nd year run of '02 KJ's(built from oct '01-sep '02) are the best KJ's made.The least amount of issues reported.
Oh and the 231 t-case is stronger then the 242 t-case.The planets need to be aligned and all that for the 242 to shift correctly with higher miles.
tjkj2002 is offline
post #6 of 8 Old 05-12-2012, 08:21 AM
DaveJKJ
2005 KJ Liberty
The 242 is still good though. I use the 4-full time all the time in the winter when the roads have drifting snow and bare spots......and 4 part time and 4 lo off road. It has had a lot of use. No problems. I change the fluid once in a while when the planets are aligned though.....
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
post #7 of 8 Old 05-15-2012, 10:22 AM
Justonefix
2002 KJ Liberty
My wife's 02 Liberty Limited
I gotta warn you I don't care for these things at all. My wife's was a pretty good car until around 100,000 and now it's falling apart faster than we can fix it. Speed sensor went so we had no speedometer. Seatbelts no longer latch or won't unlatch. Rear cv joint on front axl failed, 890.00 to fix. Now the Power Control Modul refuses to display codes and except for stating it can't find the motor. I've read the PCM can run around 1,000.00 and must be done at the dealership so they can program it. Of couse now that so many Jeep dealerships have closed (including the one that where my wife bought this thing) there's not one anywhere close to where we live. So if I had a choice between another Liberty and a bicycle, I'd buy a helmet.
Justonefix is offline
post #8 of 8 Old 05-15-2012, 10:46 AM
jeepkj617
2008 WK
I'm pushing 130,000 on mine and I beat the crap out of it some times.. ok.. most of the time..
But so far my biggest issue has been the radiator. It cracked once after a small accident, I replaced with aftermarket (biggest mistake as they suck). But other than that, it runs and drives great
"What do you mean it don't work? Just hit it with a bigger hammer!"
Thinking about buying a Cobra® 29-LTD 2-Way 40-Channel CB Radio. Anyone have install/antenna suggestions?
jeepkj617 is offline
How Hot Should A 2002 JK get? BoosLibby KJ Liberty Forum 5 06-15-2010 09:36 PM
Thinking about a KJ Rickyb KJ Liberty Forum 7 03-20-2010 03:00 PM
Thinking about getting a KK kadetklapp KJ Liberty Forum 92 05-22-2009 06:57 PM
Thinking of getting a KJ crd 2001svt KJ Liberty Forum 7 08-12-2007 08:25 AM
Thinking of the KJ again... jeep_on KJ Liberty Forum 11 03-17-2007 07:08 AM
