Tailgate Locking problem - JeepForum.com
post #1 of 4 Old 07-31-2013, 01:10 PM Thread Starter
antlery
I have a 2002 Jeep Liberty that does not have power door locks. When I lock the tailgate, usually when using the rear wiper, I can almost never get the tailgate to unlock. has anyone else had this issue and found a way to fix this or work around it? Any help will be greatly appreciated.
antlery is offline
post #2 of 4 Old 07-31-2013, 01:19 PM
brendanc
2002 KJ Liberty
I am not exactly sure (as I have power locks) but is it stuck? Maybe some spray silicon grease would help it. Don't use WD-40 as that will evaporate/go away and you'll have to keep using it all the time.
brendanc is offline
post #3 of 4 Old 07-31-2013, 01:30 PM Thread Starter
antlery
No, I don't think it is stuck. I just keep turning the key and it will eventually open. Last time it took almost 10 minutes of key turning. I actually am leaving it unlocked right now, it is so much trouble get unlocked. What is frustrating is that it is a manual lock, not power locks. When you turn on the rear wiper however, it locks up tight. Thanks for the suggestion.
antlery is offline
post #4 of 4 Old 08-01-2013, 02:46 AM
KLT88YJ
Antlery, I had/ have the same problem with my 02 KJ. The electronic lock cylinder actuator has gone/ is going bad. Basically for me one day I had full function of the tail gate and none the next, did some investigation and this is what I found.
IF your tail gate won't open get a flash light and a flat tip screwdriver, flip your rear seats down, pry open the access panel on the tail gate (lower left from inside when tail gate is shut) with the screwdriver, peel back the protective film and insulation. If you lay down in the jeep facing the rear, look into the access panel at the slight upper left and you'll see a small black nubbed end, this the end of the actuator that drives the keyed and key less operation. Reach in and flip/ toggle the switch up you'll physically hear it "click" your tailgate will now open.
While your in there you could try adding a lubricant to the moving parts or spray some electrical cleaner on them.
By doing the above it most likely won't permanently fix the problem as I've been doing the above stated for 2 plus years now. Occasionally I have to reach in through the back window and manually actuate/ flip the switch as a result I just leave that small inspection plate/ access panel off. Sometimes the lock mechanism works flawlessly for 4-6 months straight other times I might only get a week before repeating the process. I've had a hard time justifying spending the $250+ for the new switch.
Anyways, hope this helps you.
KLT88YJ is offline
