Tail light keeps burning out - JeepForum.com
post #1 of 7 Old 09-19-2013, 05:47 AM Thread Starter
AVR2
The driver's side tail light/brake light keeps burning out on my 2005 KJ. I'll fit a new bulb and get maybe a week out of it before it blows again.
There are obvious signs of overheating on the bulb holder, so is there anything I can do to fix the problem permanently? Do I just need a new holder?
AVR2 is offline
post #2 of 7 Old 09-19-2013, 11:12 AM
04liberty
2004 KJ Liberty
You probably need a new socket. Once it goes bad it burns bulbs out fast.
04liberty is offline
post #3 of 7 Old 09-19-2013, 11:34 AM
tjkj2002
2002 KJ Liberty
The little metal fingers where the bulb holder contacts in the actual tail light housing likes to melt and sink into the housing.The only real fix is to get a new tail light housing and new bulb holders(do not come with tail light housing).
tjkj2002 is offline
post #4 of 7 Old 09-21-2013, 01:23 PM Thread Starter
AVR2
I've discovered what the problem was. There's a known issue with a clear plastic surround inside the tail light housing being affected by heat over time. Eventually it breaks away and touches the bulb, creating a hotspot that quickly burns it out. I took the unit right off the Jeep and gave it a shake and what do you know, that's what had happened to mine. It's a hefty chunk of plastic rattling around inside the tail light, but it's invisible from the outside.
Officially the only fix is to replace the entire tail light housing, but unofficially you can get some needlenose pliers in there to break up the plastic and pull it out (it's toughened, so it was a real PITA). Even though the plastic is supposedly some kind of lens, there's no appreciable difference to the brightness of the light compared to the passenger side once you've pulled it out. Hopefully my problem has now gone away.
AVR2 is offline
post #5 of 7 Old 09-22-2013, 08:58 AM
4x4kingx889
2005 KJ Liberty
I have the same problem it even burnt out my led bulb after 2 months
4x4kingx889 is offline
post #6 of 7 Old 09-22-2013, 08:59 AM
4x4kingx889
2005 KJ Liberty
samething with mine I could not get the peace out tho
post #7 of 7 Old 09-23-2013, 11:43 AM
olliehopnoodle
1982 FSJ Cherokee
Same problem. I took a small wood screw (brass). Drilled a hole from the outside and pulled the clear plastic up to the outside cover. Problem solved.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
