Should I change the brake block that has the tubes coming into/out of it on the axle? How do i take it off? Anything tricky to remove and replace on these axles?
The ring gear is a long ways from where you are indicating, in the scheme of things. If anything was going to contact, it would be the pinion gear. Most likely you're seeing machine marks. Since the carrier is not in plain sight, it doesn't have to look pretty. As long as it clears, and fits, all is good.
Found answer to this post ( by that i mean i deleted what i was gonna say in this post)
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
