Suddenly getting rubbing from rear tire when offroading - worn spring or shock? - JeepForum.com
post #1 of 4 Old 06-05-2013, 11:05 AM Thread Starter
AVR2
I was driving my 2005 KJ along some rough, sandy ground today, and as I went across some dips I heard some very loud rubbing from the left rear tire. When I inspected it, I could see that the outer wall of the tire is rubbing against the inward-pointing lip of the plastic fender. It only happens when the suspension is compressed (such a when negotiating dips on rough ground), it's fine on normal pavement.
I took a look underneath but can't see any obvious problems. Is it more likely to be the spring than the shock? Can anyone tell me the factory ride height for the rear wheels, so I can measure it and see what I've got?
AVR2 is offline
post #2 of 4 Old 06-05-2013, 12:03 PM
tommudd
2004 KJ Liberty
How much bumpstop are you running ? " how high"
04 KJ WITH JBA 4 INCH COILOVER LIFT
03 KJ WITH JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #3 of 4 Old 06-05-2013, 12:28 PM Thread Starter
AVR2
It's completely stock. So whatever the factory size is.
AVR2 is offline
post #4 of 4 Old 06-05-2013, 12:31 PM
tommudd
2004 KJ Liberty
OK so with an 05 weaker springs due to being 7 years old and also the shocks then you're more than likely to get more and more rubbing
One KJ, an 06 we had here to do a lift on was 1.5 inches lower than stock and it had all kinds of rubbing issues
tommudd is offline
