Submerged my liberty/ blowing computers - JeepForum.com
post #1 of 18 Old 06-26-2013, 09:08 AM Thread Starter
timtoe
While unloading a boat I got cought up in a rut. Proceeded to back far enough to get out of rut. Past rear tire height. Up to brake pedal on driver side and seat height on passenger side.
Any help???
timtoe is offline
post #2 of 18 Old 06-26-2013, 11:13 AM
RKK
2012 KK Liberty
Any help???
Is this out of water now?
RKK is offline
post #3 of 18 Old 06-26-2013, 11:15 AM
huntb
2008 KK Liberty
You never said what's wrong with it...
huntb is offline
post #4 of 18 Old 06-26-2013, 11:35 AM Thread Starter
timtoe
Yes it is out of water.
It ran for two days afterward. Then did not start. I have power. The starter will turn over with its own power. I have no ignition or power to my fuel inj. My relays seem to be working. Also the vehicle would not communicate with my scan tool.
I cleaned a large wire harness terminal located in cab. Located on left side panel next to drivers left foot. It was green and corroded . All looked good, so I hoped I found the isue. So I installed computer I purchased at salvage yard.
Immediately I had a running truck again. BUT, then it died like it ran out of fuel. I restarted it four times and then I had nothing as before.
YIKES
This is a 2005 liberty with 3.7L and automatic trans.
timtoe is offline
post #5 of 18 Old 06-26-2013, 11:43 AM
huntb
2008 KK Liberty
You might want to check the KJ forum. They might be able to help better than the KK guys (and gals) Liberty KJ Forum
huntb is offline
post #6 of 18 Old 06-26-2013, 11:56 AM Thread Starter
timtoe
If there is a way to get this on it I would but I keep getting a pop up saying that the kj forum is not takeing new threads
timtoe is offline
post #7 of 18 Old 06-26-2013, 07:46 PM
RKK
2012 KK Liberty
The computer near driver left leg is called FDM in KK model. Is instrument panel on? When you turn the key?
RKK is offline
post #8 of 18 Old 06-26-2013, 08:03 PM
Poncherello
2010 KK Liberty
Tim Toe,
I just attempted to move your thread to the KJ forum. These fellas are pretty good at answering questions. Good Luck and hope you get your issue resolved.
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #9 of 18 Old 06-26-2013, 08:10 PM
CJATE
Did you turn the car off while submerged?
Sent from AutoGuide.com Free App
83 CJ-8 scrambler
SOA
Locked and Twin-sticked
35's, fenders cut
4.56
bad paint
leaks just about everything
CJATE is offline
post #10 of 18 Old 06-26-2013, 08:48 PM Thread Starter
timtoe
Yes I shut it off at one point. After I got pulled out it ran right away. It ran two days and probably 100 miles or more. I went to go to work on day two and trouble began.
timtoe is offline
post #11 of 18 Old 06-26-2013, 08:55 PM
CJATE
So it died under water?
when you turn key it cranks and cranks no fire?
Check your oil see if milky.
Setting in drivers seat, did your feet get wet?
83 CJ-8 scrambler
SOA
35's, fenders cut
4.56
bad paint
CJATE is offline
post #12 of 18 Old 06-27-2013, 01:45 AM
Billwill
2002 KJ Liberty
There are several connectors under the carpet.
I would advise you disconnect the battery and use a hairdryer on all connectors including the PCM.
You can download the relevant year KJ Service manual here....include circuit diagrams and pictures showing where all the connectors are located.
http://www.colorado4wheel.com/manuals/Jeep/KJ
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #13 of 18 Old 06-27-2013, 07:29 PM
oilbuner
2006 KJ Liberty
This is a troubling problem for sure. I use a product called Strike Hold. It is some amazing stuff for penetrating lubricant, displacing moisture. The military kept this a secret for quit a while. It may help you with your electrical problem. I would start with disconnecting every electric connection that got wet, dry it and spray it with Strike Hold... This stuff is amazing..Oilburner
http://www.strikehold.com/
When the pavement ends, you better have some ground clearance!
oilbuner is offline
post #14 of 18 Old 06-30-2013, 04:03 PM
RKK
2012 KK Liberty
I suspect moisture got in. how dry are your interiors now? keep the doors open and leave it in the sun todry. as far as electronic parts, there are break pedal sensor and accelerator pedal sensor. Under the gear shift harness there are few more electronics and sensors, not sure if they were under water or moisture got in, you may need to open that and dry/clean. I would use deoxit or contact cleaner to keep the moisture away for the connectors
RKK is offline
post #15 of 18 Old 07-01-2013, 11:48 AM Thread Starter
timtoe
Yup all apart and drying now.
timtoe is offline
