Strange Brake Issue, ABS? Please help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Strange Brake Issue, ABS? Please help!
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 10-24-2013, 05:11 PM   #1
bostonjeep23
2006 KJ Liberty
Hey guys,
I have an 06 Liberty with 123,000 miles. Last weekend I was driving it around and was braking down a hill, when all of a sudden the brakes felt like they were slipping and felt as if the ABS was kicking in. The roads were completely dry and I wasn't going fast or skidding or anything. No ABS or brake light or any other light came on while this happened, or after.
Brought the jeep to Midas to have them check out the brakes. Front pads and rotors were fine and the rear rotors and pads were worn out and so I replaced them, although they said this likely wasnt causing what I had described. But since I needed them anyway, figured it was worth a shot.
The day after I replaced them I drove to work (45 minute commute) with no issues in the morning, then drove home. About half way home in light stop and go traffic, I started having the same grinding/slipping of the brakes happen consistently for 5 stops in a row. Still no ABS light or any other light came on during this.
I pulled over and had AAA tow me back to Midas, where of course I could not replicate this for the guy. He said it sounded like an ABS issue, and in the meantime he turned off the ABS by taking out the fuse....
That way, if I drive it around and it happens again we can rule out ABS being the cause. If it doesn't happen, I can have them drive it around with a computer to read codes if they can replicate it.
However, I am just nervous because it doesn't happen always but there is clearly something wrong.
Does any body have any idea what this sounds like it could be? Is it ABS even though the light hasn't come on?
A couple of days prior to all of this, I had turned off traction control so that I could peel out in some gravel/dirt...could that have screwed something up?
bostonjeep23 is offline   Reply With Quote Quick reply to this message
Unread 10-24-2013, 08:31 PM   #2
Bain98xj
If I remember correctly the only time the abs light comes on is when there is a code in the system. But you could have a wheel speed sensor dropping out causing the abs to kick in.
Bain98xj is offline   Reply With Quote Quick reply to this message
Unread 10-25-2013, 03:57 AM   #3
AVR2
Correct, the ABS light only comes on during self-test at every startup, or when a problem is detected in the system.
If a wheel speed sensor dropped out (in the sense that the control unit stopped being able to communicate with it), it shouldn't cause the ABS to trigger. On the contrary, I believe that if the control unit loses a sensor, it disables the ABS and turns on the light. Any time the light is on other than during the short self-test at startup, I believe the ABS system is disabled.
AVR2 is offline   Reply With Quote Quick reply to this message
Unread 10-25-2013, 05:35 AM   #4
Bain98xj
When a wheel speed sensor drops out coming to a stop the abs kicks in because the monitor thinks that one wheel is sliding as if its on ice. So its very possible its a bad sensor
