Starting Problems w/ 2005 Jeep Liberty - JeepForum.com
post #1 of 30 Old 03-19-2012, 07:03 AM Thread Starter
GreenEyes84
2005 KJ Liberty
My 2005 Jeep Liberty has had some occasional problems starting since I purchased it in 2009. The vast majority of the time it starts up just fine, but every once in awhile, it just doesn't quite want to turn over all the way. It'll be almost there, but it just doesn't want to start. It typically happens when the car is warm (i.e. has been driven for 30-45 minutes and then left to sit for 20 minutes), and when I turn the key it just doesn't start (it WANTS to, it just doesn't quite get there). Usually, if I try a few times and turn the key extra hard and maybe give it some extra gas, it will start up. Every time I have taken it to a mechanic, I've mentioned this problem, and they'll try to figure out the issue, but they are never able to get it act up. My gas mileage has taken a major nosedive over the last few months as well. I'm not sure if they're related issues, but figured I should mention it. Any ideas?
GreenEyes84 is offline
post #2 of 30 Old 03-19-2012, 08:58 AM
snowmoose14
2005 KJ Liberty
I am just recently having the exact same problem with my 05 liberty as well. On mine I need to change the sensor on the charcoal canisters by the fuel tank and I thinkn there is one next to the fuel rails so could that be the cuplrit?
snowmoose14 is offline
post #3 of 30 Old 03-19-2012, 01:53 PM
ANG2005kj
2005 KJ Liberty
I too am having the same problem and it just started happening about a week ago, haven't looked into yet so will be watching to see what people say about it..
ANG2005kj is offline
post #4 of 30 Old 03-21-2012, 08:49 AM
05LibertyMGH
Wow....my wife mentioned this issue last night with her 2005. Hope someone has some insight on this issue.
05LibertyMGH is offline
post #5 of 30 Old 03-21-2012, 10:25 AM Thread Starter
GreenEyes84
2005 KJ Liberty
I just spoke with the mechanic (Jeep is still at the shop). He was able to get the car to act up, and found that the fuel pump wasn't turning on. He said he put a new relay on it, and that he hasn't been able to get it to act up since, but he was going to do a little more work on it just to make sure that that's the problem.
post #6 of 30 Old 03-21-2012, 12:14 PM
snowmoose14
2005 KJ Liberty
Where is the relay located if you can find out from the mechanic?
Thanks
post #7 of 30 Old 03-21-2012, 01:43 PM Thread Starter
GreenEyes84
2005 KJ Liberty
I'll see what I can do. I'm not exactly a "car-person", and "car-speak" is like a foreign language to me lol. I'll see if I can have the mechanic write down (or tell me slowly so I can write down) where the relay is. If I find anything out, I'll pass it along.
post #8 of 30 Old 03-21-2012, 03:33 PM
05LibertyMGH
4671168e
msrp $14.50
post #9 of 30 Old 03-21-2012, 04:49 PM
05LibertyMGH
Engine Bay
In front of battery, flip open fuse lid. It is relay #29. The bottom of lid has id/names of fuses.
post #10 of 30 Old 03-22-2012, 06:41 AM Thread Starter
GreenEyes84
2005 KJ Liberty
Unfortunately, I got a call from the mechanic right before I left work. He said he'd left it out in the sun to heat up (in an effort to make it act up, just to make sure that the problem was truly fixed), and sure enough, it acted up. So he kept it for the night and will be running additional tests today If I hear anything new, I'll be sure to post.
post #11 of 30 Old 03-22-2012, 09:34 AM
IgotJeep99
Did your mehanic do a fuel pressure test?
I'd have him check the ignition switch also.
IgotJeep99 is offline
post #12 of 30 Old 03-22-2012, 10:39 AM Thread Starter
GreenEyes84
2005 KJ Liberty
Just talked to him again. I apparently have low fuel pressure. They've traced the problem through the whole fuel line all the way back to the tank, but can't go any further without removing the tank. So they're going to replace the whole fuel pump module and hope that works
post #13 of 30 Old 03-22-2012, 11:41 AM
snowmoose14
2005 KJ Liberty
ok. let us now if that works!
post #14 of 30 Old 03-22-2012, 03:01 PM
IgotJeep99
Maybe just changing the fuel pressure regulator will fix the problem. If your lines are clogged then new fuel filter is good the replace.
How much did they quote you for the job?
post #15 of 30 Old 03-22-2012, 03:03 PM
IgotJeep99
edit: also just wanted to add, fuel pump's job is to pump fuel and not provide pressure. They maybe just changing to get $$ off you. Have them change fuel filter and fuel pressure regulator and go from there.
Problems with 2005 Jeep Liberty aquaman_06 KJ Liberty Forum 7 07-19-2015 06:30 PM
2003 jeep liberty starting problems hmel KJ Liberty Forum 15 04-22-2013 07:42 PM
2005 Liberty starting problems allstar13850 KJ Liberty Forum 0 02-25-2012 08:00 AM
03 Liberty 2.8 diesel UK with starting problems - Help ! shorehambeach KJ Liberty Forum 2 12-12-2011 08:12 AM
i need help with my 2005 jeep liberty crd please. twirlymaster KJ Liberty Forum 4 05-29-2010 11:01 PM
