Spring Compressor - JeepForum.com
post #1 of 5 Old 07-29-2009, 06:10 AM Thread Starter
asax08037
Spring Compressor
Last weekend I was trying to replace my front shocks, but the spring compressor didn't fit into my springs(03 Liberty). I need to know what brand of spring compressor will fit stock liberty springs.
asax08037 is offline
post #2 of 5 Old 07-29-2009, 05:21 PM
95BadBoy
Many auto parts stores do the "loaner" tool thing. Did that for my TJ when I lifted it. Have not changed springs on the KJ yet - so can't help on the right one. But it is info that I'm sure I'll need in the near future.
So at least this is a bump for you.
Did you do a search ?
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #3 of 5 Old 07-29-2009, 10:58 PM Thread Starter
asax08037
I did do a search, but the one that came up was the same one that I already tried.
post #4 of 5 Old 07-30-2009, 07:41 AM
jeeplibby1
I recently replaced my front cv axle shaft. I had to remove the lower part of the strut referred to as the clevis. I thought that I would have to compress the spring to release the tension. No rental tool that I found would fit, the coil is too tight. After searching, I found that the spring has virtually no tension on it when the Jeep is lifted (with the jack not on the lower arm of course). With it lifted you can remove the lower clevis bolt, and the bolts that hold it in place in the engine compartment. The assembly will drop out and then you can check and see if it looks like the energy in the spring is released.
jeeplibby1 is offline
post #5 of 5 Old 07-30-2009, 07:42 AM
jeeplibby1
Oh, and be careful.
06 Liberty AC Compressor djroot2 KJ Liberty Forum 4 08-07-2014 11:29 PM
Spring Compressor asax08037 KJ Liberty Forum 1 07-26-2009 07:00 PM
Spring Compressor asax08037 KJ Liberty Forum 0 07-20-2009 10:32 AM
Air Condition Compressor destructo678 KJ Liberty Forum 1 07-03-2009 02:36 PM
02 AC Compressor jesserb306 KJ Liberty Forum 2 05-01-2008 06:53 PM
