Slight jerk from back end when accelerating hard - JeepForum.com
post #1 of 7 Old 03-23-2012, 05:28 AM Thread Starter
AVR2
My 2005 KJ has started making a slight jerk from the back end when you're moving slowly - say about 20-30 mph - and then open the throttle up. There's no wheelspin or noise, just a slight sensation of the back end "catching up" with what the engine is doing. It only lasts a fraction of a second.
Is it likely to be a driveshaft or (gulp) diff issue? It's still on the original rear driveshaft, although the front was replaced about 2 years ago. The trans was rebuilt less than six months ago, so I'm not thinking it's a transmission problem.
AVR2 is offline
post #2 of 7 Old 03-23-2012, 05:41 AM
notstuck
Try greasing the spline in your drive shaft, check axle u-bolts, make sure they are tight. Drop the diff cover and inspect the spiders. Remember.... wheel....bend........repair.......repeat.
notstuck is offline
post #3 of 7 Old 03-23-2012, 05:49 AM Thread Starter
AVR2
Cool, thanks. If I open up the diff, what am I actually looking for? Obvious signs of mechanical damage?
AVR2 is offline
post #4 of 7 Old 03-23-2012, 04:37 PM
jamesdart
i have a similar thing going on with mine, i think its in the Y link. either the bushings or the ball joint.
jamesdart is offline
post #5 of 7 Old 03-23-2012, 09:05 PM
notstuck
Look for the obvious. Also check the pinion yoke. I have spun the pinion on my old cj a couple times. rear diffs are not that hard. Get a manual for youre model of rear/front diffs and tear into it. Pay close att. to torq specs
notstuck is offline
post #6 of 7 Old 03-24-2012, 02:10 AM Thread Starter
AVR2
If it turns out to be worn components inside the diff, can you make repairs with the axle on the Jeep? I just don't have the facilities for dropping the axle and working on it off the Jeep. Everything has to be done in the parking lot of my apartment building.
AVR2 is offline
post #7 of 7 Old 03-24-2012, 04:01 AM
notstuck
I am a backyard mechanic at best but yes you have to pull axles to get the guts out Check all mounting points Suspenion bushings and mounts. Sometimes a second pair of eyes helps also. A buddie and a couple beers and look at everything might be something simple. At least I always hope so. good luck.
notstuck is offline
Hot Air from defroster when accelerating! erob61 KJ Liberty Forum 3 10-03-2010 09:31 PM
Liberty rolls back on slight incline JeepPower KJ Liberty Forum 5 01-22-2010 05:49 PM
Sudden jerk joseph1977 KJ Liberty Forum 1 07-05-2009 12:51 PM
Am I the only one who is having a hard time seeing to back up at night? swyszomirski KJ Liberty Forum 15 11-09-2004 08:30 PM
Automatic Gear Change Jerk Red Hackle KJ Liberty Forum 5 07-20-2002 02:04 AM
