Serpentine belt - JeepForum.com
post #1 of 8 Old 04-20-2007, 01:51 AM Thread Starter
kitch
Serpentine belt
Hello fellow Jeep owners. I知 new to Jeep having owned my Cherokee (UK) 3.7 LTD for 1 week now, I知 very pleased. But the serpentine belt is shredding with bits wrapping them selves around the fan. I have removed all the bits and the belt is still attached but only about 2/3rds of its normal width. Now I知 no mechanic is replacing the belt an easy DIY job or does it need special know how?
kitch is offline
post #2 of 8 Old 04-20-2007, 07:27 AM
JSlack
If it's the same 3.7 configuration as mine, it's very easy once you know how to DO it. I had this same question just yesterday, and luckily was able to find it on another website. (actually a combination of several websites)
So here's how you do it. As you face the engine, there should be a diagram under the hood on the radiator apron showing the serpentine belt routing. On that diagram, it ought to point to a specific pulley on the lower left-hand side of the engine (as you face it) that is the tension-release pulley. If you don't have this diagram, it's the small pulley that is as far down and to the left as you can get (as you face it), not the smooth one, the one with grooves. Put a 15mm socket on that pulley and exert CLOCKWISE torque. If your auto-tensioning pulley assembly is working properly, that pulley will rock inboard and will relax the tension on the belt enough for you to slide it off.
This is all contingent, of course, on you having the same engine and auto-tensioning assembly configuration. Good luck!
JSlack is offline
post #3 of 8 Old 04-20-2007, 07:28 AM
JSlack
Oh...right. I think the Liberty IS the Cherokee in Britain... Ooops!
Yes, this is the correct method for you, then.
Also, if your serp belt is shredding, it might behoove you to do a proper inspection of your pulleys to make sure they don't have any jagged edges that might be shredding your belt. I've heard some folks say that the tensioning pulley has a tendency to crap out and ruin belts.
JSlack is offline
post #4 of 8 Old 04-20-2007, 08:13 AM
valvestem
valvestem's Avatar
valvestem is offline
post #5 of 8 Old 04-20-2007, 08:22 AM
BVCRD
If this happened here in the USA one week out of dealership, the service dept. would have it back on their doorstep making thing right. With or without friendly persuasion.
2006 Jeep Liberty Sport CRD
BVCRD is offline
post #6 of 8 Old 04-20-2007, 08:57 AM Thread Starter
kitch
Thanks for the responces, unfortunatley is a used jeep bought privatley so I have no come back. I found a local(ish) specialist who changed the belt in minutes. But half a mile down the road it snapped. So it seems to be a pully problem which the garage is now looking into. Hope this is only small teething problem.
kitch is offline
post #7 of 8 Old 04-20-2007, 09:00 AM
JSlack
I sure hope so too! Good luck.
JSlack is offline
post #8 of 8 Old 04-20-2007, 02:00 PM Thread Starter
kitch
new pulley has been ordered, hope its not too expensive.
kitch is offline
In a jam with serpentine belt JSlack KJ Liberty Forum 2 03-12-2012 02:08 PM
Serpentine Belt Replacement grichey KJ Liberty Forum 21 07-21-2011 10:44 PM
Serpentine Belt issue, leaking oil jeepninjagirl KJ Liberty Forum 0 04-15-2009 08:28 AM
HELP! Liberty CRD serpentine belt change?? guyronson KJ Liberty Forum 2 01-07-2009 05:45 PM
Serpentine Belt Mateo94XJ KJ Liberty Forum 0 05-12-2005 11:42 PM
