Serpentine Belt - JeepForum.com
post #1 of 5 Old 06-27-2012, 03:57 PM Thread Starter
RVD56
2008 KK Liberty
Serpentine Belt
Need to replace my serp belt, but the parts store by me says there are 2 belt size options and I cannot find any info on this. Both belts have mostly the same specs except the outside diameters are different. I will list them below and if anyone has any info on which is for a 2002 Liberty Sport 3.7L with A/C, it would be appreciated. Maybe one size for no a/c, and one for with a/c???
Thanks!
Rob
Belt Option 1:
Rating: OE Quality (OEQ)
Section: K
Number of Ribs: 6
Top Width (in): .807
Top Width (mm): 20
Outside Circumference (in): 86.835
Outside Circumference (mm): 2206
With 86-3/8 Inch Belt Outside Circumference
Belt Option 2:
Section: K
Number of Ribs: 6
Top Width (mm): 20
Outside Circumference (in): 87.91
Outside Circumference (mm): 2233
With 87-1/4 Inch Belt Outside Circumference
RVD56 is offline
post #2 of 5 Old 06-27-2012, 07:26 PM
tjkj2002
2002 KJ Liberty
Buy your serp belt at the dealership,it's the EPDM belt that is the best out there and yes it's pricey.Don't forget to put in a new tensioner also,the whole assembly,as the internal spring wears out just like the belt.
tjkj2002 is offline
post #3 of 5 Old 06-28-2012, 07:56 AM
jp7794
2006 KJ Liberty
Thanks!
Rob
Belt Option 1:
Section: K
Number of Ribs: 6
Top Width (mm): 20
Belt Option 2:
Section: K
Number of Ribs: 6
Top Width (mm): 20
Your numbers don't make sense. 86 3/8" should be 86.375 and 87 1/4" should be 87.250. I replaced mine with this belt and idler pulley for just under $70. I did the math and the circumference of the belt is 87.292".
jp7794 is offline
post #4 of 5 Old 06-28-2012, 02:05 PM Thread Starter
RVD56
2008 KK Liberty
Numbers are theirs, not mine. Copied/Pasted off of their website. I will replace both the belt and tension pulley. Thanks to you both!
RVD56 is offline
post #5 of 5 Old 06-28-2012, 02:55 PM
tjkj2002
2002 KJ Liberty
Just make sure you replace the whole tensioner and not just the pulley.Also make sure you get a EPDM belt,only OEM(for '02 KJ's) and Gates make EPDM belts for the KJ.
tjkj2002 is offline
In a jam with serpentine belt JSlack KJ Liberty Forum 2 03-12-2012 01:08 PM
Serpentine Belt Replacement grichey KJ Liberty Forum 21 07-21-2011 09:44 PM
Serpentine Belt issue, leaking oil jeepninjagirl KJ Liberty Forum 0 04-15-2009 07:28 AM
Serpentine belt kitch KJ Liberty Forum 7 04-20-2007 01:00 PM
Serpentine Belt Mateo94XJ KJ Liberty Forum 0 05-12-2005 10:42 PM
