Rusty's Offroad Coil Spring Spacer lift... opinions? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Rusty's Offroad Coil Spring Spacer lift... opinions?
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 12-26-2009, 08:37 PM   #1
LibRoller
2002 KJ Liberty
As the title says I'm looking for opinions on this lift. I'm probably going to get it within the week but wanted to see what guys on here thought (maybe someone who has it but if not I still want your comments).
Thanks & Gig 'em!
LibRoller is offline   Reply With Quote Quick reply to this message
Unread 12-26-2009, 09:05 PM   #2
tjkj2002
2002 KJ Liberty
Stay away,will cause more issues then anything.If possible do a full coil lift,less problems.Ruxty's coil lift uses OEM spring rates,for better coils check out the OME coils and struts/shocks.
tjkj2002 is offline   Reply With Quote Quick reply to this message
Unread 12-26-2009, 09:09 PM   #3
LibRoller
2002 KJ Liberty
So are there any kits out there you would recommend or should I piece it together? (shocks, springs, etc)
Unread 12-26-2009, 10:07 PM   #4
tjkj2002
2002 KJ Liberty
If you can afford it the OME lift will be about the best,replaces all the coils(choice of light duty,medium duty,and heavy duty) and struts/shocks.Give Dirk at DPG Offroad a call for all your OME needs--Home Page.
But if cost is a issue,try the DayStar spacer lift,much better spacer lift.With being a '02 you are probably in need of new struts and shocks anyway so it's a good time to do those as well anyways.
