Is running 85w140 dino gear oil ok in the diffs? - JeepForum.com
post #1 of 21 Old 11-18-2013, 04:10 PM Thread Starter
Jeepguy4276
2002 KJ Liberty
The jeep doesn't see a lot of heavy duty use. Researching things I decided to go Dino and a few mentioned this weight. It does get cold here. I had trouble finding many choices so it was 80w90, 70w90, and the 85w140. I went with the 85w140 because it came in a gallon and quarts. Since I'm doing both I thought the gallon discount was worth it. I know the heavy weight will give me a minute decrease in mpg but the better protection seems worth it. I would thinks the oil will warm quickly as well even when cold. I also thought the thicker oil would stick to the gears longer when not moving.
So am I doing good running this weight? Again, I've decided on Dino so please no Dino vs synthetic. Just asking on the weights.
Also, I do change fluid often, more often than is needed. It's cheap and easy so I change it, and other fluids usually once a year unless I run through deep water. Same with air filter and plugs. I've got the time and it gives me something to do.
Jeepguy4276 is offline
post #2 of 21 Old 11-18-2013, 05:35 PM
tjkj2002
2002 KJ Liberty
I run 85w-140 in both my diffs,I'm required to in my rear diff as both are not stock.The best protection for your diffs,syn gear oil is bad.
tjkj2002 is offline
post #3 of 21 Old 11-18-2013, 05:46 PM
95BadBoy
With the regular fluid changes that you already do, with either 80/90 or 85/140 should not be an issue. And yes - dino is really the best bet.
As cold as it gets here sometimes, I wish that I had 80/90 in all rigs during the winter.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #4 of 21 Old 11-18-2013, 08:13 PM
tommudd
2004 KJ Liberty
Been running 85-140 dino in mine for years , no issues at all
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #5 of 21 Old 11-19-2013, 07:21 AM
DaveJKJ
2005 KJ Liberty
85-140 dino here in both diffs. No problems.
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
post #6 of 21 Old 11-19-2013, 07:25 AM
2007LIB
2007 KJ Liberty
My owners manual says I should use synthetic in the rear dif. of my 2007. Is there a difference for that year? I have used synthetic with other vehicles with no issues.
If it ain't broke don't fix it.....Enjoy it.
2007LIB is offline
post #7 of 21 Old 11-19-2013, 08:06 AM
tjkj2002
2002 KJ Liberty
Only states that for the extra .10mpg it gives.
tjkj2002 is offline
post #8 of 21 Old 11-19-2013, 10:39 AM Thread Starter
Jeepguy4276
2002 KJ Liberty
What difference do you notice? I can't imagine the minute change in mpg's would be noticeable and I would think it warms up fast even with our cold temps. I guess I don't know what difference I might notice. You know the temps we deal with. I was thinking the thicker may help since the axels take a bit of pounding here. They tires spin on ice then catch hard as the hit dry pavement.
So what differences should I be noticing?
post #9 of 21 Old 11-19-2013, 10:52 AM
tjkj2002
2002 KJ Liberty
In the rear diff you will not notice any change besides a very small drop in mpg's in the very cold,but your getting bad mpg's anyway so another .1 mpg drop will not be noticed.
Cold weather performance between 75w-90,57w-140,80w-90,and 85w-140 is not really noticeable since they all are 75w through 85w when cold,it's the hot performance that changes.
tjkj2002 is offline
post #10 of 21 Old 11-19-2013, 12:21 PM
2007LIB
2007 KJ Liberty
The most wear of any gear train occurs at startup when it is cold regardless of outside temperature and it is prudent to alleviate this wear by using a product that starts working as quick as possible to lubricate the gears.
I have noticed in the past that Synthetic oil is a lot cleaner than ground oil when it is changed and gives me a gut feeling of giving me more power .
I think the extra price is worth it and feel more secure in knowing that I have the best protection around.
The extra mileage also indicates that the lubrication is better.
However, everyone is different, just like the oil....
2007LIB is offline
post #11 of 21 Old 11-19-2013, 12:36 PM
2007LIB
2007 KJ Liberty
Just a footnote....
I have also been using Slick 50 in my engines for about 20 years and swear by it(took a Chrysler 2L 4 banger to 300,000 km and still going).
2007LIB is offline
post #12 of 21 Old 11-19-2013, 12:44 PM
tjkj2002
2002 KJ Liberty
For differentials and there splash oiled system synthetic gear oil is the worst.What makes synthetic oil great in a forced oiled system(has a oil pump) like cold flow rate makes it bad in a diff that relies on just a ring gear to "splash" the oil over everything that needs to be lubed.Conventional gear oil,while less flowing, will stay in place better for better lubrication,also will transfer heat better,and the shear strength is better since diff are not a forced oiled system.
Dino gear oil will look worse after some time but it does it's job much better.All newer vehicles have very short OCI's on syn gear oil since it does not protect diffs very well.Just look at 2 of the best aftermarket axle builder,Currie and Hi9,and for there hard core axles they demand 85w-140 non-syn gear oil only as syn gear oil will not protect and destroy those diffs in short order.
My $4000 rear axle is best protected by $4.99 a qt 85w-140 non-syn.I can change out my rear diff fluid(3qts for change out) for the price of 1qt of syn gear oil.
tjkj2002 is offline
post #13 of 21 Old 11-19-2013, 12:47 PM
tjkj2002
2002 KJ Liberty
Just a footnote....
Just a footnote............
Sold my fathers(just passed away) '01 F250 PS with 802,000 miles(not KM) on the original engine,only used Cenex CO-OP 15w40 non-syn oil changed every 5,000 miles.
tjkj2002 is offline
post #14 of 21 Old 11-19-2013, 01:01 PM
2007LIB
2007 KJ Liberty
Wow.......got me there....I'm glad there are different opinions and points of view out there otherwise it would be a very boring forum and a world full of robots.
2007LIB is offline
post #15 of 21 Old 11-19-2013, 01:03 PM
2007LIB
2007 KJ Liberty
And my condolences to you and your family.
2007LIB is offline
