Rumble strip noise at decel - JeepForum.com
post #1 of 4 Old 05-13-2012, 05:56 PM Thread Starter
Rocket
2007 KJ Liberty
Hello all, as topic states I am getting a rumble strip noise at decel and bad vibration when coming to a stop in my 2007 Jeep liberty limited (stock). I took it to a shop near my work and they test drove it and said bad torque converter but they never even put it on a lift, so I asked how they knew and they explained there was a bulletin for it. They hand me a bulletin and I read it and it says it for the diesel model so I became suspicious especially when they wanted $1200 to fix it. I drove it home and Saturday took it to a local mechanic that I have used before, he said he wasn't positive where it was coming from after he put it on the rack. All my boots looked good no oil or grease leaks anywhere so he suggested I take it to a Jeep store. After doing some research I see the rear U joint can cause this so I crawled under my Jeep and since my son has my jack stands I could not get it off the ground safely I did a visual inspection, I did see one of the rubber seals on the rear u joint is away from its original position, but I could not feel any slop. Could that be enough to make the U joint bad?
Rocket is offline
post #2 of 4 Old 05-14-2012, 11:20 AM Thread Starter
Rocket
2007 KJ Liberty
Update, Jeep is fixed was the rear U Joint it was seized that is why I couldn't feel any slop. Love this forum just saved me $1100 due to the fact I researched the issue and Google pointed me here or I may have accepted the first shops opinion and had the torque converter replaced for $1200 bucks Instead cost me $110 for a U joint replacement.
Rocket is offline
post #3 of 4 Old 05-14-2012, 02:40 PM
jp7794
2006 KJ Liberty
Thank you for updating. I am sure there will be others with the same issue that this will help.
jp7794 is offline
post #4 of 4 Old 05-14-2012, 06:20 PM Thread Starter
Rocket
2007 KJ Liberty
No problem, and she's home in the garage now and the ride home was smooth once again.
Rocket is offline
Front End Rumble jimymc KJ Liberty Forum 14 01-21-2010 03:50 AM
Rumble Rumble Exhaust Life Mountie KJ Liberty Forum 4 02-22-2009 05:07 PM
2003 Liberty front end constant rumble the_tones_guy KJ Liberty Forum 5 01-09-2009 07:14 PM
Liberty noise! Rear end. Rumble strips GottiJr KJ Liberty Forum 1 04-02-2008 12:26 AM
Rumble @ 30 MPH & 40 MPH KhakiSport03 KJ Liberty Forum 3 05-01-2007 09:37 AM
