Has anyone had any issues with a 2.5" Rough Country lift, specifically with the front strut coils hitting or rubbing the frame/sidewall? I know with any lift, the angle of the front struts is brought in, so to speak. Whenever I go over a sharp angled obstacle (like a narrow/tall speedbump, or large pothole, or some railroad tracks) faster than 10mph, I hear a loud bang from the front suspension, as if the strut coil hits against something. I had the lift professionally installed a while ago, and the guy said this would probably happen. Just curious if anyone else has had the same problem. Also, it doesn't look like the bump stops have even been touched, so it's not hitting there, and seems to happen when fully extended, not compressed.
I have the same issues. When I redo my front end soon. I'm taking the spacers to a machine shop and have 3/8 of an inch taken off the big section. This should help clear the inner fender. What happens is during the alignment. The shop has to move the lower control arm inward to get the camber back in. The only true way to fix it is with the JBA$395.00 extended Upper control arms. +The Rocky Road UCA is not longer than factory so it won't help. )This will allow the alignment shop to bring the lower control arm back out.
I'm not surprised. The Teraflex lift also needed aftermarket upper control arms to make things right again. I went with RRO instead of JBA and saved a few bucks.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
