Rocky Road 2.5" Lift & 265/70/R16 Tires - JeepForum.com
post #1 of 4 Old 04-17-2007, 06:54 PM Thread Starter
1badxj
I will be buying a 2005 CRD in a few weeks and the 1st thing I plan to do as soon as I take title is add the lift and tires. Thing is, I'm wondering if I can use the stock rims or not. If so, will it require a wheel spacer? And what about tire fitment issues? I'm a little new to Libby's, so just thinking out loud here.
2005 Rubihara #111 of 1000
(SOLD) 2005 Liberty CRD
(SOLD) 2003 Reg. Cab Dodge 2500
1badxj is offline
post #2 of 4 Old 04-21-2007, 07:28 AM
RAYMAN975
im not sure if the 265's will fit without a spacer. crawl under the door and look at the front suspension by the brakes, you will see how little room there is between the inside of the tire and the steering knuckle/upper ball joint. a lot of guys run a 245-75-16 with about 2.5-3.5" of lift and are happy, some people need trimming, some people dont. some guys run the 265-75-16 and they look awesome, but are prety big and will definitely have rubbing issues, nothing TERRIBLE, but youll have to do some mods, like behind the front bumper and behind the front tire by that pinch weld sticking out, people usually use a heatgun for the front, and a hammer for the pinch weld.
2002 Cactus Green Jeep Liberty Renegade 4WD
1989 Red Honda Prelude 5-speed 4WS
RAYMAN975 is offline
post #3 of 4 Old 04-21-2007, 10:26 AM
CRD4Liberty
I wouldn't install a standard Rocky Road lift on a CRD, the front springs will be WAY, WAY to light to carry the diesel engines weight. Also not a fan of their rear shocks. All J's has the only designed and assembled CRD lift I know of. Rocky's may have access to the 500 lb new OME front springs for the CRD now also. I'd also for sure not run anything but an OME front strut with that new heavy spring, the best rear shocks are also OME, but are custom ordered, sized and valved for AllJ's Frankenlift.
The Frankenlift comes with everything already assembled so you have no real extra costs if you install yourself. Install isn't technically difficult but takes 4-6 hrs depending on your toolbox/abilities.The others you have to assemble the front strut/springs and may have to buy extra shocks and such at a later date. For sure you want at least a better rear shocks.
Either way you'll need a frontend alignment done ASAP after any lift.
Forgot to mention the 32 inch tires like the 265/75 and 235/85s will keep your back glass from openning unless you space the carrier somehow, Have heard of some taking off the carrier and rotating it to get more clearance, but have no real knowledge of it working on 32 inch tires. The bigger tires are much heavier than the stockers so at a later date the carrier or door may not like the extra weight anyway. Rock Lizard is making a rear bumper, with a swing tire carrier as an extra for this reason.
CRD4Liberty is offline
post #4 of 4 Old 04-22-2007, 06:52 AM
LoneLiberty
2004 KJ Liberty
I hope you're not considering the 2.5" Budget lift, if so, it's junk and stay away from it.
If you're talking about the Rock Father II, it has H.D. OME springs with a coil rate of 375 lbs., Your front stock springs have a 400 lb. rate. Bad choice again!
Look to All J's site for their new CRD coil lift.
Slightly Modified O4 Liberty LTD
Pix/Mods:
LoneLiberty is offline
Rocky Road Outfitters Business Practices on Ebay (BEWARE) clarkm5562 KJ Liberty Forum 11 01-27-2015 04:53 PM
3" Lift, 32" Tires, Will It Work? Murphyman KJ Liberty Forum 44 10-26-2013 09:18 PM
Rocky Road lifts for KK 08 or 09 UberMX5 KJ Liberty Forum 7 12-11-2009 12:49 PM
Insurance Totaled "05" Rocky Mtn. Edition firechief KJ Liberty Forum 8 07-18-2009 07:23 AM
Rocky Road Outfitters & their Budget Kit Wooders KJ Liberty Forum 8 07-12-2006 08:01 PM
