Ride in the Liberty after a lift - JeepForum.com
post #1 of 4 Old 03-15-2002, 04:15 PM Thread Starter
KJLiberty2002
I recently had the 2.5" lift done on my liberty, but I've found that after going over speed bumps, etc. the front end seems to "slam" back down. It's extremely rough. Does anyone have any idea what might be the problem. I had the daystar 2.5" coil spacers installed. Thanks for the help!
Matt AKA KJLiberty2002 2002 Jeep Liberty Sport 4x4 - Garnet Red. Modified: 2.5" Lift running P245 75 R16 BFGoodrich All-Terrains.
http://www.geocities.com/mattjanete/photos.html
KJLiberty2002 is offline
post #2 of 4 Old 03-16-2002, 09:51 AM
Liberty-4-All
There is plenty of information on the problems of the 2.5" Daystar Puc lift. Most vendors are now offering a "cutdown" version of the spacers. I cut my own to 1.25". The problem is that you are putting a 2.5" spacers inside the limited space of a strut. Without longer strut inserts, you have compressed the front spring too much. With 4" of upward travel, you have effectively removed 2.5". That leaves your struts with 1.5" of travel. It is really not safe to drive on a suspension that is that stiff on the road. Your rear shocks will also top out because they are not long enough to extend with the extra 2.5" of static extension.
Either contact who sold you the spacers, cut your spacers down to size ( not all that easy ) or drive careful and wait for the longer strut inserts. Rusty's has had some on order and in the making for months. He already has the longer travel rear shocks and they do help.
You should not even try going off-road with the setup as it is. I hope this helps and doesn't discourage you.You should read this thread from JeepsUnlimited...
Lift Installation Questions
02 Sahara Edition KJ
Best Mod...PowerTrax No Slip Locker
265/75/16 Maxxis Buckshot Mudders
ARMOR, ARMOR, ARMOR
LLL=15.75"
L.O.S.T.member #000001
Visit
I got your Grocery Getter Hangin'
Liberty-4-All is offline
post #3 of 4 Old 03-16-2002, 09:00 PM
Kenny 96 XJ
Kenny 96 XJ's Avatar
by using just spacers without new and longer coils or shocks, you simply maxed out your stock suspension travel. That is why the front end does "slam" back down on the bump stops.
A friend of mine had the Rusty's spacers installed but he had them removed and is now waiting for longer replacement Shocks and coils in order to solve the problem.
96 XJ Sport having the 6 cyl engine as the ONLY factory option
4" custom lift, 31" Yokohama Geolandar A/T + II, Quick disconnects, no rear sway bar
Kenny 96 XJ is offline
post #4 of 4 Old 03-17-2002, 02:14 PM Thread Starter
KJLiberty2002
So the Rusty's struts should solve the problem that I'm having? Thanks!
What lift? How's it ride? LIBAR8R KJ Liberty Forum 16 10-04-2006 12:59 PM
Which lift is most like a stock ride? polivo KJ Liberty Forum 6 07-24-2006 04:27 PM
Is the Liberty a secure ride enid360 KJ Liberty Forum 21 04-26-2004 08:34 AM
Liberty after Lift clarkm5562 KJ Liberty Forum 8 03-31-2004 04:17 PM
Lift kit for Liberty BLK2000XJ KJ Liberty Forum 3 04-30-2003 03:49 PM
