Repair washer reservoir - JeepForum.com
post #1 of 7 Old 05-19-2012, 07:12 PM Thread Starter
Hmullin
2003 KJ Liberty
My reservoir is leaking ('03 renegade) and it looks impossible to access. Any ideas how to reache the thing?
Hmullin is offline
post #2 of 7 Old 05-19-2012, 08:54 PM
kjjohn
You can access the reservoir by removing the right side mud guard and side fender. I was installing a snorkel the other day and could see the reservoir and all the connectors ('05 KJ)
kjjohn is offline
post #3 of 7 Old 05-20-2012, 01:39 AM
Billwill
2002 KJ Liberty
There is a good chance you may have bumped the pump motor or pipes.
If you are lucky something is disloged and not broken.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #4 of 7 Old 05-20-2012, 02:04 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Also, since it's not a pressure vessel, it can be easily repaired. If it's cracked, just get the crack realigned (if it's displaced, you may have to push it out from the inside with a stick...) then either smear epoxy or polyester resin (Bondo gel, fibreglas filler resin) over it.
If it's bad, get a fibreglas kit and cut a patch to fill it in, and resin inside/outside.
Sorry I can't give you advice on how to remove the tank - but I don't know the KJ, and don't like how things get hidden on new cars anyhow.
For the lines on the bottom of the tank, I find it helpful to secure them using zip-ties, pulled nice and tight. You have to cut them off, but if you're going to cut them off, the hose probably wants replacing anyhow.
(Finding a screw hose clamp that small probably isn't very easy...)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 7 Old 05-20-2012, 11:28 PM Thread Starter
Hmullin
2003 KJ Liberty
Thanks guys.
Guess I sort of guessed that: "removing the right side mud guard and side fender". However, my real question is how to remove the mud guard? Looks like there are black button type joiners. I don't see any way to remove these (look like they are push in type) without breaking them. Also, does the fender need to be removed too? Looks like a bear too - there are some stud looking bolts on the outside but no screw fittings - inside looks impossible.
Hmullin is offline
post #6 of 7 Old 05-21-2012, 05:23 AM
kjjohn
Originally Posted by Hmullin
Thanks guys.
I installed a snorkel so I had to remove the fender and mug guard. There are 3 different types of connectors that need to be removed. The simple "push in pull out" ones that are on the mud guard, then there are those that require you to pull out the middle bit then pull out the fasteners. Then the rivets, these I just cut out because they are rivets! I have a set of jeep rivets that I replaced.
Refer to the service manual for help. Good luck.
kjjohn is offline
post #7 of 7 Old 05-21-2012, 08:40 AM
Billwill
2002 KJ Liberty
I was able to get to the washer pump on my 2002 CRD from inside the front-right wheel well....you simply move a section of the rubber away.
Billwill is offline
crush washer ODGREEN4X4 KJ Liberty Forum 1 08-25-2011 08:36 PM
Front Windshield Washer? polivo KJ Liberty Forum 1 11-03-2010 07:59 PM
Motive Brake Bleeder Reservoir Cap Part Number? g22 KJ Liberty Forum 0 03-23-2010 12:28 PM
Self filling washer fluid??????? Mr_Harry KJ Liberty Forum 10 08-08-2009 08:08 PM
Where is the power steering reservoir? liberated KJ Liberty Forum 1 01-05-2008 09:55 AM
