Take a screwdriver or a knife stick it between the baffle around the radio and the dash and pry a little. However there is a screw behind the ashtray. Becareful and dont pry too hard. Dont break the baffle. Also I hope that you bought a dash kit and a wire harness. You are going to need them. Also don't expect the speakers to sound too much better unless they are not OEM.
Use a spatula or wide ended tool, it will make it easier to remove. It comes of very easily once you remove the screw behind the end of the "ashtray space" or the hallow space beneath the A/C controls. You might have to shift the transmission so make sure you pull the brake before you do the work. I removed my stock radio once before to check the (lack of) connections behind RBQ..
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
