rehashing 3.5" or 4" lift options for jeep liberty kj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > rehashing 3.5" or 4" lift options for jeep liberty kj
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 12-19-2015, 09:35 AM   #1
libertyordeath8
2003 KJ Liberty
Just about to order the JBA upper a arms and wondering; what exactly.would i need to lift a little higher than my current 3" without needing to buy machined cv axles? (Because i just put a couple thousand clicks on my new stock ones)
I have some upper isolators for the rear, ive read about a conduit nut for the clevis? Will i need longer brake lines?
libertyordeath8 is offline   Reply With Quote Quick reply to this message
Unread 12-19-2015, 10:19 AM   #2
tommudd
2004 KJ Liberty
Depends on what year you have as far as brake lines 05 later just a drop down bracket is needed
What lift do you have now?
You can gain 3/4 of an inch with a 3/8 inch clevis
Going to 4.10s with larger tires ?
04 Liberty, Kilimanjaro Edition, Rock Lizard RockRails/Roof Rack/Front-Rear bumper,32 inch Goodyear Duratracs,Moabs,4.10s/ 4.25 inch JBA Coilover lift /other goodies
tommudd is offline   Reply With Quote Quick reply to this message
Unread 12-19-2015, 10:35 AM   #3
libertyordeath8
2003 KJ Liberty
Oh sorry, i will log in to website and fill out recent mods in a bit, for now i have 4.10s 927/948 ome with bilstein lift and the rear jba extension bracket, its a 2003, i just put in new wheel hubs, cvs and a front detroit truetrac! Oh and 245/75 r16s
Ok great! But i guess for my year i will need the brake lines hey? And how do you do the clevis lift? Spacer type thing?
Unread 12-19-2015, 10:44 AM   #4
tommudd
2004 KJ Liberty
03 no bracket needed for rear brake lines
If you have 927s in front do you have a top plate or anything else ?
Use 1/4 inch top plate for 1/2 inch lift, takes you to 3 inches, add a 3/8 inch clevis which will take you to 3.75, anything above 3.5 you'll have some UCA/ spring contact anyways so be prepared for that
Unread 12-19-2015, 10:49 AM   #5
libertyordeath8
2003 KJ Liberty
Great!! Yes i do have the 1/4 top plate, will i get contact even with the new JBA upper a arms? with the clevis do i just go get a 3/8 spacer and put it on the bottom of the front shock?
Unread 12-19-2015, 10:54 AM   #6
tommudd
2004 KJ Liberty
All depends between 3.5 and 3.75 is where most get their contact ( yes even with JBA arms)
Unread 12-19-2015, 11:06 AM   #7
libertyordeath8
2003 KJ Liberty
Oh. Thats unfortunate.. well does the contact occur on the rubber boot? Or is it just metal on metal at full extension type thing? Cuz with my.stock a arms i get contact right on the boot and it tore a bit, but i can live with metal.on metal
Unread 12-19-2015, 11:08 AM   #8
tommudd
2004 KJ Liberty
The spring hits the metal part of the arm, right behind the ball joint , only slight but it does
Unread 12-19-2015, 11:15 AM   #9
libertyordeath8
2003 KJ Liberty
Great! I didn't plan on going any higher but now i got the itch to lift lol
On a side note! I been seeing a looot of lifted kjs in my area these days...... poke poke
So just to confirm, what is the best way to do the clevis if you dont mind? Anything else i need on my order from JBA?
Unread 12-19-2015, 07:11 PM   #10
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Most just use 3 inch conduit nuts - three of them at 1/8" thick equals 3/8" total, which will lift your KJ 3/4" of an inch. The conduit nuts go on the bottom of the shock between the bottom of the shock mount and the clevis. They are really just on there for spacing purposes; you can just lower the clevis 3/8", tighten the bolt down and leave it. Personally I like having the conduit nuts in there just in case the clevis bolt isn't tight enough - prevents it from sliding up. It's up to you.
If I were you - and you have the funds - I'd buy a set of JBA's upper control arms. Your alignment will be in factory spec and you'll HATE the banging from the stock upper control arm hitting the spring. It happens over even mild bumps - happened on mine and I quickly ordered the JBA arms and got them installed. Quiet as a church mouse now
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, 4X Guard Trans skid, Factory Engine, T-case, Tank skids, Modded BoulderBars sliders, OME 927/948, Bilsteins, JBA A-Arms & 1/4" top plate, 1 extra rear iso/side, Moabs with Firestone Destination AT's 255/70-16
TwoBobsKJ is offline   Reply With Quote Quick reply to this message
Unread 12-19-2015, 07:33 PM   #11
02blue
2002 KJ Liberty
Bob
I think you mean 2" conduit nuts.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline   Reply With Quote Quick reply to this message
Unread 12-19-2015, 09:15 PM   #12
libertyordeath8
2003 KJ Liberty
Thanks guys! I didnt want to leave a void betwen the clevis either, this is what i was lookin for. Yes, i just lived with the contact on the springs. Ive been running this lift for over 20k clicks or so (wheeling it too!) And my tie rods and a arm ball joints all went at same time haha, mind you; there are over 260k km on the body of this one
Getting to the point now where i could have put in a SFA haha, wonder how easy a dana 30 would bolt up?
Unread 12-20-2015, 03:54 PM   #13
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
You're right - trying to type fast while on pain meds doesn't work.
Thanks for the correction
Bob
Unread 12-25-2015, 10:15 AM   #14
libertyordeath8
2003 KJ Liberty
Merry xmas everyone!
So just still curious about the rear brake lines after doing the extra lift by adding a upper coil isolator; i have pulled my rear swaybar to eliminate the contact from the rear uca bracket bolt... will the extra flex cause any pull on the rear brake lines? Or is it fine at 3.75" of lift?
Thanks as always!
Unread 12-25-2015, 10:28 PM   #15
tommudd
2004 KJ Liberty
Thanks as always!
Post number 4
