Regular or synthetic? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > Regular or synthetic?
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-11-2015, 09:33 AM   #1
303jeepkj
Just got my 05 liberty in December and it has 97500 miles. I'm curious how many miles and what type of oil, regular or synthetic everyone is using.
Thanks!
303jeepkj is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 09:58 AM   #2
Tombo_ontario
2002 KJ Liberty
I'm at 190000kms (118000miles)...Mobil 1 synthetic 5w-30
Tombo_ontario is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 02:28 PM   #3
kjsteve
2002 KJ Liberty
98800; Pennzoil 5w30 regular
KJ-mostly stock for now
Fr. Mopar recovery hooks and rear Curt receiver tow hook
Discoverer A/T3
kjsteve is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 04:18 PM   #4
boboborino
I am ~106000 KM(~69000 miles) on our '02 and have chose to go with 10-30 regular GTX for the summer. I will switch it out with 5-30 come fall.
Bert
boboborino is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 09:09 AM   #5
streetglideok
2005 KJ Liberty
Bert
Why such a thick oil when its designed to run with 5w30? Cant tell me you all have heat in the summer up there, as I'll laugh Too thick of oil will damage oil pumps and the relief springs.
streetglideok is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 09:10 AM   #6
streetglideok
2005 KJ Liberty
104k and have been running Mobil1 5w30 since I bought it with 44k on it. 4-5k miles between services.
Unread 04-12-2015, 02:48 PM   #7
tommudd
2004 KJ Liberty
214,000 been running Mobil 1 synthetic since my first change at 500 miles , changed every 3-3500 miles
04 Liberty, Kilimanjaro Edition, Rock Lizard RockRails/Roof Rack/Front-Rear bumper,32 inch Goodyear Duratracs,Moabs,4.10s/ 4.25 inch JBA Coilover lift /other goodies
tommudd is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 05:28 PM   #8
boboborino
I am well above the operating temperature range for the 10 weight at this time of year. It's hard for me not to be sarcastic considering we recently just got electricity and running water to our igloo!
Bert
Unread 04-12-2015, 05:47 PM   #9
billiebob
10-30 has been an industry standard forever. I run 10-30 in the summer too. 5-30 winters if I plan going some where cold. Where I live our record low is -15C or +5F. 10-30 works fine all winter here. I do 2 oil changes a year... spring and fall.
Must be a Canadian thing. I used to work for a company called Igloo Building Supplies.
My Uncles first Jeep was a Government Issued Jeep in 1944.
Back when ALL Jeeps were Government Issued.
billiebob is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 06:03 PM   #10
tommudd
2004 KJ Liberty
Yes screw what the manufacturer recommends....................
By the way I run 5W30 what they recommend
Unread 04-12-2015, 06:22 PM   #11
02blue
2002 KJ Liberty
Me too. Full synthetic now and every 3-4k with a wix filter. The good stuff definitely helps my oil fill condensation issue.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 08:08 PM   #12
Cropduster23
I acquired my Liberty at 139,000 miles. The previous owners had used Pennzoil 5w-30 from new until 90,000 miles. At 90,000 miles they switched to Pennzoil High Mileage 5w-30. I have kept using Pennzoil High Mileage 5w-30 since I took ownership (2 changes so far. 1 on day of purchase and 1 today) I change my oil every 3000-3200 miles and I use a Purolator Pure 1 (gold box) oil filter.
Cropduster23 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2015, 09:17 PM   #13
303jeepkj
Appreciate the responses. The one thing about oil is just about everyone has a different opinion. I went Mobil 1 5w30 synthetic and Mobil 1 filter.
Unread 04-12-2015, 09:34 PM   #14
streetglideok
2005 KJ Liberty
Dunno where you got your info, but you're pretty far off base. SAE single viscosity oils were the standard far longer than 10w30 was, and the industry moved right along to 5w30 and 5w20 after that. 5w30 has been the recommended year round oil for nearly all spark ignition engines for over 20 years, and the majority of them for 30 years. That's far longer than 10w30 ever reigned. If you want to use a substandard weight for your engine, I guess more power to you, considering 5w30 is the recommended oil from the guys who made what you drive, for anything below 38*C. Let me know the last time you guys saw heat up there, and I'll invite ya down to Oklahoma or Texas for a week in August. Seeing how I work on the things and get paid to fix what people screw up, I can tell you what happens to people who start thinking they are one up on the engineer. You get longer cold start starvation of critical components, and increased wear of them as a result and of the oil pump. You increase the likelihood of cavitation in the pump that wears them out faster as well. You put undo strain on the oil pressure relief, causing future oiling issues, even when warmed up. These things aren't sloppy fit like your old engines that ran SAE 30. Much, much tighter tolerances, and thicker oil means it moves much slower, even when its spiked to 60psi or more. Guess what the camshafts ride in? Yep, straight up aluminum, not a bearing like you see on an old chevy or Chrysler 318. Yes, the specs say you can run 10w30 to -18C, however that's for when you have to, not that you should. They don't want you to and for good reason. Just make sure you put that disclaimer when you want to stray away from what they want you to run. If you're feeling brave, go get yourself a 5.7L Hemi, and run that 10w30 all the time. I dare ya, I need a good laugh
Unread 04-13-2015, 05:00 AM   #15
boboborino
WTF are you talking about? They recommend either 5W30 OR 10W30. The 5W30 is "(Preferred)" only because of the idiots that don't change out to 5/30 for when it gets cold. I never said I run the 10/30 all year long! You guys are the funny ones!If anybody knows COLD it's us Canadians and our freindly American neighbours (with the "u") to the North in Alaska!
Bert
