As shown there is a cable that has an end that doesn't connect to anything . There is a plastic piece where this cable connects to the track that breaks & a plastic piece where the regulator connects to the bottom of the window that also breaks . If the motor runs but doesn't move the window , I'd look for a broken plastic piece .
The one in the link is for a front window , rear are similar but a little different so you will need one for whichever window isn't working if the regulator is the problem . There are front & rear & left & right .
Hmm. I will tell you that this cable (with a spiraled-end) will sit there and spin if I activate the window control. Like, it will bulge up and make noises as it scrapes up the door. Is that what it should be doing?
Sounds like regardless, plastic is broken, and it's time for a new window regulator....
If you look at the link , out near the end of that cable there is what looks like a black zip-tie with a nipple on it . That nipple pops through a hole in the door panel only to keep the cable from rattling around in the door . Sounds like you have something broken on your regulator .
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
