rear upper control arm - JeepForum.com
post #1 of 2 Old 09-16-2013, 03:10 AM Thread Starter
USPLiberty
I've been hearing some clicking/clunking lately in the rear of my Liberty and noticed that the body mounts of the rear upper control arm are loose. I think the rubber bushings inside gave out. I can easily move them up and down with my hand. These shouldn't move loosely correct?
Has anyone replaced this yet? Easy/hard job?
Thanks
USPLiberty is offline
post #2 of 2 Old 09-16-2013, 06:34 AM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Thanks
Yea, if you can move it like that most likely that's the source of the clunking. The ball joint that attaches to the top of the differential is probably shot too.
Pretty easy to replace - hardest part is usually getting the ball joint to separate from the diff. You can work to remove the joint from the clamp-like component attached to the diff or remove the clamp from the diff when you loosen the tri-link (upper arm) and remove it. Then separate the joint from the clamp when it's more accessible.
Purchase a Mopar tri-link. Yes, there is a big price difference between the factory and aftermarket pieces but this is a "get what you pay for" situation. The factory unit will last much longer than aftermarket so you don't have to do this replacement again for a long time.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
